Tubes for BJ
Discussion in 'Amp Central Station' started by exnavyabfc, Dec 3, 2018.
  1. exnavyabfc
    exnavyabfc NEW MEMBER!
    NC
    I just bought a older (?) BJ with a Cannabis Rex in it. I play my 72 Reissue Thinline Tele mostly and some Strats. I try to play the Blues just for fun. The amp seems to be ok and plays well, but it was acting funny, little hiss or crackle so I did the tap on the tubes test. The one all the way on the right (looking in back) glows a lot redder and when tapped on does not sound like the rest. More hollow thud than ring. So I'm gonna replace all tubes. What do you guys suggest?
  2. swany
    swany Tele-Meister
    Evergreen, Colorado
    In my blues Jr. I prefer the mullard 12ax7 . I feel it warms it up a bit.
  3. SixStringSlinger
    SixStringSlinger Friend of Leo's Silver Supporter
    Space
    I like tubes as much as the next guy but that's asking too much.
  4. LeicaBoss
    LeicaBoss Tele-Holic
    New Jersey
    Depends. New Old Stock RCAs? Maybe...
    If you're going to do it to replacement go to the Tube Amp Doctor. Get a select matched pair for the output section. Live a happy life.
    BorderRadio and MrCairo46 like this.
  5. LuthRavin
    LuthRavin Tele-Meister Ad Free Member
    Eugene, Oregon
    When I bought mine used it still had the stock tubes in it.. so like my Vox AC10 i ordered new tubes for it..Mullard's in my AC10 they worked like a charm..in my Blues Jr it sounded harsher..so I pulled them out and reserted to stock ones..sounded better..so I left them in. I might try them again at some point but I'm pleased at this present time..
  6. corliss1
    Lansing, MI
    The amount of glowiness (highly technical term, I know :D ) has nothing to do with the functionality of a tube.
    You should want as little sound as possible when you tap a tube to perform that test. I'd much prefer the thud than the ring from your description.
    Crackling could certainly be from tubes, but it could be any number of other things as well, such as bad solder joints (a known issue in Hot Rod series amps) or resistors. You could swap tubes and still end up with the same issue, which would mean it's tech time for that amp.
    teletimetx likes this.
  7. Chiogtr4x
    Manassas Park, VA
    I run JJ EL-84's now ( have also used EHX- branded Sovteks too) in power section, and low noise ( EHX, TAD, or Tung-Sol) 12AX7's throughout 18 years with a 2000 BJ
    - ALL sound very good, and last very long time- BUT I do have a good tech ( who installed a bias pot) when tubes sound flat/ lacking dimension, or if something's making noise
    But all good for 2-3 years since last ' checkup' - routine gigging...
  8. KC
    KC Friend of Leo's
    Missoula, Montana
    or you could just meander over to eurotubes, tell bob whether you want early breakup or max power, drop a new set of JJs in the amp and you're off to the races. I've had good luck with this route
    mcfm2n, SPUDCASTER and bblumentritt like this.
  9. Bartholomew3
    Bartholomew3 Friend of Leo's
    Montreal
    Nobody else got it ?
    MrCairo46 likes this.
  10. bblumentritt
    bblumentritt Tele-Afflicted Platinum Supporter
    Austin, Texas
    For V-1 I often like the Mullard New Production 12AX7.
  11. MrCairo46
    MrCairo46 Friend of Leo's
    Baltimore, Maryland Hon!
    I needed a good laugh at work today.
  12. teletimetx
    teletimetx Doctor of Teleocity
    Houston, TX
    ...post no 4 got it, as well...
    anyway, one premise I work from is that there's always tons of info out there that can be helpful or just interesting to learn.
    there's a fella who spent quite a bit of time with the Blue Junior, in all of its iterations and you could learn a few things, just browsing around. Here's a link:
    http://billmaudio.com/wp/
    In any event, an "old" Blues Junior might actually be in the age range where the filter caps might ought to be replaced and finding a good amp tech is always a good thing. There's many DIY folks here that do their own work, and there are some cracking good amp techs here as well, but if your not looking at this like a deep dive into to amp tech, then taking that old Blues Junior into a tech for a good once over will be another learning experience.
    You are apparently somewhere in North Carolina, and you might ask around for some recommendations.
    ...and JJ tubes work fine. Probably a good starting reference point; no need to buy the farm just yet.
  13. RLee77
    RLee77 Friend of Leo's
    Nevada
    :lol::lol::lol:
    A quick handshake and a fair price is as far as I'm willing to go!
    Paul in Colorado and Silverface like this.
  14. Marc Morfei
    Marc Morfei Tele-Afflicted
    Philadelphia, PA
    I used JJs in mine and they sounded fine. I had a CRex speaker in mine, too.
    mcfm2n likes this.
  15. Andy B
    Andy B Friend of Leo's Silver Supporter
    Colorado
    My favorite tubes for a Blues Jr. are: V1 TungSol RI 12AX7, V2 Sovtek 5751, V3 Sovtek 12AX7LPS, V4 & V5 Sovtek or Electro Harmonix EL84.
  16. zombiwoof
    zombiwoof Tele-Afflicted
    Tujunga California
    Is he asking for a straight trade?. ;)
    bender66 and swany like this.
  17. gitapik
    gitapik Tele-Holic Silver Supporter
    New York City
    That's your preamp tube. The hollow sound when you tap it (with a pencil eraser?) usually means it's either shot or on it's way out. I don't think you need to buy a full new set if it's just that one tube.
    I like the JJs 12AX7 for a clean sound base. Follows the controls well when you dial in the dirt. Price is right, too.
    Got a bunch on this page. I like their model, too (preferred series).
    https://www.thetubestore.com/preamp-tubes/12ax7-ecc83-tube-types
  18. exnavyabfc
    NC
    Thank you all for your advice,,and I may trade if you are as hot as they are......:)
  19. Paul in Colorado
    R.I.P. 2019
    Yeah, my inner adolescent thought the same thing. ;-)
  20. Billnchristy
    Billnchristy Tele-Afflicted
    Georgia
    I’ve got some to trade. :lol:
