Tube Screamer at 12v?
Discussion in 'Burnt Fingers DIY Effects' started by Trey jr., Apr 2, 2013.
  1. Trey jr.
    Trey jr. Tele-Meister
    Appleton
    As long as the caps are rated high enough and the IC can handle it, it should be fine to run a ts at 12v, right? What would the difference in sound be? Just higher headroom like you hear about with running other pedals at higher voltages? I just feel like if a ts could be run at a higher voltage, it would be a hot topic on the interwebs. Especially since the ts is such a popular pedal.
  2. Montana_Dawg
    Montana_Dawg Tele-Holic
    Sure. With a few adjustments here and there. The main reason it is 9V is because you don't see any 12V batteries out there. I don't think a car battery would be feasible due to portability issues. :)
  3. tjk3052
    tjk3052 Tele-Holic
    The wild wild midwest
    I haven't tried it, but there really shouldn't be a difference in headroom because the diodes clamp the signal before it reaches the rail voltage.
