Tube Amp Amperage Draw?
Discussion in 'Amp Central Station' started by MacFangus, Jul 13, 2020.
  1. MacFangus
    MacFangus TDPRI Member
    Down South Jukin'
    Does anyone know how much amperage a 50 tube amplifier draws? I'm thinking about getting a variac that's rated at 1.75 amps to run my Marshall at 115VAC to 117VAC. Lower voltage settings will result in increased amp draw, of course... but, will it exceed 1.75 amps at high volume @ 115VAC voltage setting?
  2. Blrfl
    Blrfl Tele-Holic
    Northern Virginia
    Every electrical doohickey sold in the U.S. is required to have a plate somewhere that lists its maximum power draw. That figure will be in watts. Divide that by the voltage and you'll get current in amps.
    MacFangus likes this.
  3. dan40
    dan40 Tele-Afflicted
    Richmond Va
    Yes...I believe the mains fuse value for a 50 watt Marshall is 3 amps. The fuse will be slightly overrated to prevent premature failure so I would guess the amp draws 1.5-2 amps under heavy load. That's just a guesstimate but I would look for at least a 5 amp variac at the minimum.
  4. schmee
    A 50 watt Bassman draws about 1.5 amps
    dan40 and MacFangus like this.
  5. MacFangus
    Down South Jukin'
    Thank you, everyone. To be sure, I'll get something that's rated at 4 amps or higher. I just thought a smaller size variac would be a better fit.
