Do yourself a favor. (I did!) look at the Headstrong lil’king or if you want the option of gobs of clean head room the lil’king S . Great amps. Hand wired Princeton reverb. The S has a 12 inch speaker and will give you about 30 watts. Great bass response. I did an outdoor show. And it just killed. For the gigs I usually do I had more clean headroom than I need. So I had it re biased to run on 6v6’s which reduces output to around 20 watts. Perfect I pair it with a tweed deluxe clone that puts out about 18 watts and run a tps style wet dry set up. But a lot of the time just use it by itself. All you need grab and go!Hi everyone!
I'm looking for a great all-tube amp to play in small venues or rooms, using a Gibson ES-335 — no mics, mostly blues and jazz.
Ideally, I'm after a clean base tone, vintage-inspired and Blackface-oriented, with enough headroom to add a light overdrive or boost pedal for some grit. I'm aiming for something in the 10 to 20 watt range.
A Fender Princeton Reissue '65 (or even better, the '64 handwired) seems like a solid candidate, though I'm particularly drawn to boutique amps — the Tone King Falcon really caught my eye, for instance.
I’m coming from a Fender '57 Custom Champ, which I love with a Telecaster, but it never really worked for me with the ES-335. It’s also quite limiting volume-wise: turning the knob not only increases loudness but drastically alters the tone.
Any thoughts, recommendations, or experiences to share?
Thanks!
