Truss rod orientation
Discussion in 'Tele Home Depot' started by pypa, Nov 27, 2020.
  1. pypa
    pypa Tele-Meister Ad Free Member
    new jersey
    I have built a couple guitars so far and have usually put the truss rod in the neck with the flat side up (against the fretboard). However this requires routing a deeper recess near the nut end that I usually do by hand. It’s a pain.
    Does anyone orient their truss rods with the round side toward the fret board? I could just make the entire channel deeper. This would also put the adjustment nut a tad higher which I think would be better.
    thoughts??
    C82F5B02-96E7-4414-B6BA-D5AC287287C9.jpeg 9EBA23B6-3419-46E9-AB01-15138A02E42E.jpeg
    crazydave911 likes this.
  2. pypa
    new jersey
    Never mind. I just stop routed it on the router table. I normally hate this kind of operation, but there’s so little material being removed, it’s pretty easy to control
    Even if climb cutting.
    54CEAAAD-B7DE-4D02-ADE2-9521FE9848EC.jpeg 5F89686A-57D7-473A-9311-EB8227521EE6.jpeg
  3. 1bad914
    1bad914 Tele-Afflicted
    Michigan
    That was what I was going to recommend. You beat me to it. Lol
  4. pshupe
    pshupe Tele-Meister
    Hamilton
    Just remember that the adjustment would be backwards if you put the rod in upside down. So clockwise would actually add relief, not the other way around.
    Cheers Peter.
  5. Freeman Keller
