Truss Rod Nut Stopped, Neck Still Bowed
Discussion in 'Tele-Technical' started by KW1977, Jun 14, 2020.
  1. KW1977
    KW1977 Tele-Meister
    Virginia
    Hello all. Just picked up a gorgeous partscaster Tele. MJT body, Musikraft neck(22fret, 9.5”), Rutters hardware. The setup wasn’t too great upon arrival - intonation off, action quite high, so I set about correcting things. I got a couple slow 1/4 turns in and the truss rod nut just stopped, so I did too. No further. Only trouble was the neck was still fairly up-bowed, action at slide height, still can’t get the intonation set as a result.
    What does it sound like I’m dealing with here? Broken? Stripped? Normal? I did clamp it into a slight back bow and no market improvements. Btw—This isn’t a blackguard neck with the adjusting but at the heel, this is one you adjust from the headstock with the walnut plug.
  2. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    If you loosen the adjustment nut a few turns you can see if there is damage to the surface that the nut presses against, which is not the worst thing in the world to fix, a lot better than a broken truss rod etc. Then as a stopgap you can put a washer ground to the proper size & shape under the adjustment nut and it will pull a bit further before bottoming out, hopefully enough to get the action you want. Good luck!
    Jlwctn likes this.
  3. KW1977
    KW1977 Tele-Meister
    Virginia
    Unfortunately the nut isn’t removable on this style neck.
  4. jfgesquire
    jfgesquire Tele-Afflicted
    Lake View
    Did you measure the actual relief? How low are the saddles?
    Sent from my LG-H932 using Tapatalk
  5. KW1977
    KW1977 Tele-Meister
    Virginia
    Got it to .060 at the 12th. Low & high E saddles are close to bottom, not a measurement I took.
  6. jfgesquire
    Lake View
    Yuk...
  7. charlie chitlin
    Egremont, MA
    That is an action measurement, right?
    If you fret a string at the first and last frets, what is the string height midway between?
  8. tubegeek
    Brooklyn, NY
    Drat.
  9. 3-Chord-Genius
    Winchester, VA
    Whenever I hear about a problem involving the truss rod, I cringe because I know it's probably going to be bad.
  10. reckless meanie
    reckless meanie Tele-Holic
    Bend, OR
    Can you take a picture of the nut?
  11. moosie
    Western Connecticut
    Let's see this non-removable nut, please.
    My advice otherwise is always to fully remove it, and apply vaseline liberally to the threads before re-inserting. (Get your minds out of the gutter you guys...)
    fenderchamp likes this.
  12. telemnemonics
    We need a relief measurement, the action measurement has nothing to do with the truss rod adjustment.
    I'm assuming the .060 at the 12th fret is action height!
    Saddles close to bottom could be relief or neck angle.
    If you didn't measure the relief, how do you know there is too much?
    Might be worth emailing Musikraft about it to find out if you have a single or double action rod. As of now they only offer a dual action at the head that's hidden, or a bullet that's AFAIK single action. And single action rt double action heel adjust for a total of eight truss rod options. Probably double action.
    You can reset the neck with heat, but that's for another thread after the diagnosis!
    I'd also loosen the strings slack, then loosen the nut until there's no resistance on it, counting the turns. I'm actually not sure how that rod would act in between pulling and pushing for the two actions, but running it through the range without string tension would give you a better idea of what it's doing. Check with a straight edge and note when it becomes straight without string tension, then confirm that the rod will both add back bow and add relief.
    If it starts adding back bow after a turn or two, maybe the neck is fine but the neck angle is off, and the action problem is not relief related.
    We don't know what you know and can't see the guitar, so with no relief measurement in a thread asking about too much relief, we are shooting in the dark. Also of course many non techs feel the nut get tight as it actually starts to move the neck, and think that tight feel is the end of the threads, so stop in fear of stripping.
    We just don't know what's happening with the info provided.
    Matthias, boredguy6060 and moosie like this.
  13. hopdybob
    hopdybob Tele-Afflicted
    netherlands
    loosen the nut
    clamp the neck a bit more than you want, so make the backbow a bit bigger, than fasten the trussrod but not to much so the rod would break
    loosen the clamps gently and see if the backbow hold.
    string the guitar and tune it to pitch and wait a while.
    still have to much backbow? gently loosen the trusrod a quarter turn and wait a while.
    if it is not right, do it again and again untill you have the right relief.
    Matthias likes this.
  14. BryMelvin
    BryMelvin Friend of Leo's
    Arivaca AZ
    prety sure it is. You just have to remove the plug
  15. KW1977
    KW1977 Tele-Meister
    Virginia
    Semantics on my behalf. Indeed, not something I’m currently equipped to handle.
  16. KW1977
    KW1977 Tele-Meister
    Virginia
    Will take that measurement this evening
    telemnemonics likes this.
  17. Matthias
    Matthias Friend of Leo's Gold Supporter
    Third rock from the Sun
    @telemnemonics has nailed it. Lots of options to check before attempting surgery.
    As it's a partscaster with set-up issues, have the nut slots been filed to a proper depth or is it high at that end of the neck too? Best to sort that before relief if not.
    Whiteymin, telemnemonics and KW1977 like this.
  18. KW1977
    KW1977 Tele-Meister
    Virginia
    Indeed, going to remeasure this evening.
  19. KW1977
    KW1977 Tele-Meister
    Virginia
    Upon further inspection the nut slots do appear a little proud to me(especially the D & G which were the most problematic to intonate) and that was my next move. Just sorta panicked when I felt the truss nut stop cooperating a little early on.
  20. Jlwctn
    Jlwctn Tele-Meister
    Indiana, USA
    KW1977 likes this.
