Truss rod nut question---can I easily remove/replace?
Discussion in 'Tele Home Depot' started by backporchmusic, Feb 21, 2020.
  1. backporchmusic
    backporchmusic Friend of Leo's
    I've got a Squier CV tele with a very very stiff but movable (functioning) truss rod nut. Can I simply remove it and replace it with another or is there a more complex operation involved than any other nut removal?
    Will it just tumble on out?
    It is also just slightly rounded and I want to check the threads, which add to my reasons for wanting to give this a go.
  2. jfgesquire
    jfgesquire Tele-Holic
    Lake View
  3. guitarbuilder
    If the nut comes right off leaving threads, than you can replace it, assuming the threads are the same pitch on the new nut. Vintage style rods work like that. If it is a two way rod then the nut is most likely brazed on there.
    backporchmusic likes this.
  4. boredguy6060
    boredguy6060 Poster Extraordinaire
    Sou Cal
  5. backporchmusic
    Thanks for all the answers. Looks like not a simple pull/replace.
