Tru oiled neck mods
Discussion in 'Finely Finished' started by Gaz_, Mar 6, 2021.
  1. Gaz_
    Gaz_ Tele-Meister
    Shropshire
    About 18 months ago I tru oiled the neck of my kit built 12 string tele. I like the finish, and find it plays nicely, but I've been thinking of modifying the neck. The neck is a very fat profile, so I've been thinking about sanding a few mm off the back of it and maybe rounding off the headstock a little.
    My question is, what's the best way to go about it with the tru oil, could I patch it afterwards or would I need to fully remove it first, and if that's the case, how?!
    I'm getting ready to take it to pieces for a fret level, so I'm just trying to work out if it's worth doing both. Although as I type this I talking myself out of it... But it would still be good to know for the future!
    And because we all like pics, here's my masterpiece. Riccy strung 12 string telecaster, q pickups esquire in the bridge, Creamery toaster mid 63 in the neck, 5 way switching with separate volume and tones. This thing SINGS! 16150339867793858034722033708242.jpg
  2. Tarkus60
    Tarkus60 Tele-Meister
    Salem In
    amazing
    Gaz_ likes this.
  3. fraser
    fraser Tele-Afflicted
    Hamilton, Canada
    Just do the sanding work and afterwards apply more tru oil.
    Unless theres a tint in there ( doesnt appear like there is from pics) it will look fine.
    i would likely give the existing finish a good wipe with naptha to be sure nothing prevents the new oil from sticking is all.
  4. RomanS
    RomanS Poster Extraordinaire
    Vienna, Austria
    +1
    I actually did this with a TruOil-treated Warmoth roasted maple neck a while ago; it's one with a boatneck profile (soft V), and after I had been playing it for a while, i wanted to soften/flatten the "spine" - took off maybe half a mm from the nut to around the 7th fret. After I did that with coarse sandpaper, I blended the transition to the TruOil-treated rest of the neck with a finer grit, then applied two more coats of TruOil - can't see the transition at all!
    old wrench and Gaz_ like this.
  5. Gaz_
    Gaz_ Tele-Meister
    Shropshire
    Amazing thanks, I knew someone would know! I don't hate the neck, it's nice and wide which I like, but it is very round backed. And as a rhythm guitarist I find chording gets trickier higher up the neck which isn't helped by me tuning to D standard, while the rest of the band tunes to standard so I'm always into the fatter bit! When I first cut the headstock I liked the straight edge look, but as it's gone on I think it's the only bit left that makes it "homemade".
    So it sounds the the mods could be fairly painless (except the fear of sanding through to the truss!)
    Cheers All!
    old wrench likes this.
  6. Luthier Vandros
    Luthier Vandros Tele-Afflicted
    Down by ya mom an them's
    Gorgeous.
    I just finished re-profiling one of my maple necks and had to sand through the tru-oil finish i previously applied. As long as you aren’t building up layers for a clear gloss finish, there will be no witness lines. You will see a difference in shade between the old and new, where the older finish will have ambered. Nothing a trip to the tanning salon or a few days in the sun won’t fix.
    Gaz_ likes this.
  7. old wrench
    old wrench Friend of Leo's
    corner of walk and don't walk
    I did exactly the same thing that Roman did :).
    I originally finished the neck with TruOil, but I just couldn't get used to that "V" shape down in cowboy territory.
    So after about a year, I did a subtle re-shape of the neck and re-finished with T.O.
    You really can't tell where or how the finish blended in - it looks good.
    T.O. is a very forgiving finish ;).
    Gaz_ and RomanS like this.
  8. BigBillow
    BigBillow Tele-Meister Silver Supporter
    Oh
    fwiw, a cabinet scraper is a great way to slowly reshape neck profile.
    Good luck, it’s (still) gonna look great when you’re done!
    Gaz_ likes this.
  9. stefanhotrod
    stefanhotrod Tele-Holic
    germany
    Truoil is the most forgiving and most versatile finish ever. Sand that neck and put on new coats of Truoil.
    Know what? You can even finish plastics and bakelite with Truoil. It works!
    Gaz_, RomanS and old wrench like this.
