tru-oil or nitro on bare wood
Discussion in 'Finely Finished' started by hemingway, Jul 13, 2012.
  1. hemingway
    London, UK
    For my next parts build I'm ordering a zebrano body, for which I want a natural finish. I've found this tru-oil technique
    http://www.lmii.com/carttwo/truoil.htm
    which, if you miss out the pore-filling stage (which I would) doesn't sound too difficult.
    However, I'm thinking that any oil product will darken the pale grain of the zebrano quite a lot. And I'm thinking that nitro won't darken it quite so much.
    So my question is, will clear nitro stick okay to bare wood? By the way, I won't be wet sanding and buffing and all that malarkey - I don't mind orange-peel finish, and I know that if I tried the whole buffing thing I'd make a mess of it.
  2. Shepherd
    Shepherd Friend of Leo's
    Maple Ridge, Canada
    Any finish you apply will darken the grain a little. You can get an idea by wiping on some thinner. Tru-oil and nitro are both amber in color so it will darken the wood a little more but give it a warmer tone. If you want a clear finish then a waterbased product will do that.
  3. Tom Pettingill
    Tom Pettingill Tele-Holic
    California
    Here is some Tru Oil on zebrawood
  4. hemingway
    London, UK
    Lovely, maybe oil is the way to go.
  5. Arbiter
    Arbiter Banned
    self-banned
    Yes. The only wood I've ever had problems with the finish staying stuck to it would be some exceptionally oily cocobolo (literally could wipe off the oil seeping out of the wood with a paper towel and it would be wet again ten minutes later) but that's not by any means a normal situation.
    Vinyl sealer or dewaxed spray shellac is always recommended as a basecoat but I've done quite a few guitars without either and it was not a problem.
  6. hemingway
    London, UK
    I'm really looking forward to this build. I've found some zebra wood knobs as well - although I can't decide if they'd be overkill.
    I'm doing it without a scratchplate. I just can't bring myself to cover that grain.
    Just have to wait for Axemaster to get my favourite neck in again, and I'm spendin' money.
    Will be my first ever strat, too.
    And after that, no more builds . . .
  7. originalmatthew
    originalmatthew Tele-Holic
    Riverside, California
    And after that, no more builds.... hmmm.... lol!!!
    I use Watco Danish oil for a lot of my finishes. When I want to grain fill, I use a piece of 400gr wet/dry and wet sand using the oil as the "wet". After wet sanding, I let the oil gum up and then scrape off the excess with a credit card. Then I let it dry, sand lightly to remove any more excess oil, and then finish. Works like a charm with a bit of practice...of course, the finish is satin, but you can get a pretty good shine on that satin if you let it cure and buff it. Just my 2 cents.
  8. hemingway
    London, UK
    No more builds, seriously. The wife wants holidays and furniture, not more guitars.
    The body arrived today, and it's stunning, and beautifully finished. Got it from this guy. Definitely recommend him.
    http://www.owenjacksonguitars.com/index.html
  9. piece of ash
    piece of ash Friend of Leo's
    Sugar Land, TX
    If you're geuinely worried about "messing something up", Tru Oil is your friend.
    ANY finish will alter the appearence a bit... all about reflection/refraction.
  10. Keyser Soze
    Keyser Soze Tele-Holic
    Johnson City, TN
    Tru-oil will darken any wood somewhat, with an already pale woood this may actually be less of a concern. More so than 'darken' it will add some yellow/amber. If you are trying to keep the lighter stripes as white as possible this could be a concern.
    The simple approach is to try a test application somewhere non visible (neck pocket, pickup route, etc.) If you are not satisfied with the results from TO then your best alternative would be a water based acrylic - in general they are the most 'water clear' of all the finishes.
  11. scat4me
    scat4me Tele-Afflicted
    Miami Florida
    Has anyone used True Oil on a bare spalted maple body?
  12. Glen Smith
    Glen Smith RIP
    Bump !
  13. scat4me
    Miami Florida
    Spoke to a Luthier today and was told that he never uses True Oil on spalted maple because it is so porous. So I am wondering if anyone has had a problem with other finishes on spalted maple.
