Tru-Oil and Tile
Discussion in 'Finely Finished' started by El Tele Lobo, Apr 16, 2021.
  1. El Tele Lobo
    El Tele Lobo Poster Extraordinaire
    Anyone know how to remove long-dried Tru-Oil from an uneven tile surface. Asking for a friend...
  2. El Tele Lobo
    Bueller?
  3. Mark617
    Mark617 Tele-Meister
    Massachusetts
    You can layer Tru Oil to even surfaces out. Wet sanding at higher increments helps the process. Go slowly allowing for each coat to cure, before proceeding to the next. Stop when you get the desired look
    985plowboy likes this.
  4. schmee
    schmee Doctor of Teleocity
    Goof Off is what I would try.
  5. Sea Devil
    Sea Devil Friend of Leo's
    Brooklyn, NY
    Goof-off won't work, AFAIK. Chemical stripper will, heat might.
    El Tele Lobo likes this.
  6. stratisfied
    stratisfied Tele-Holic
    Midwest
    Try mineral spirits and a toothbrush. If that fails (depends how long the oil finish has been on) then use lacquer thinner and a toothbrush. It's always best to try the least aggressive solvent (mineral spirits) before moving up to a more aggressive solvent. If the toothbrush and solvent doesn't do it, then use the solvent and a green scotchbrite pad. Stay away from the grout or mask it off.
  7. lammie200
    lammie200 Friend of Leo's
    San Francisco
    Glazed tile or porous tile?
  8. El Tele Lobo
    O believe it is glazed.
  9. lammie200
    San Francisco
    Try lighter fluid.
  10. Pawdog
    Pawdog TDPRI Member
    Denatured alcohol "may" work. I've used it to remove small amounts of Tung Oil from my tiled floor with success.
