FlatAffectCamper
Made one of these DIY signal tracers as per this link.
I have a ab763 Super Reverb and I'm trying to identify the source of hiss. I have been through dozens of forum posts and replaced just about everything in the amp, so at this point I'm trying to just do it the right way and find the source, and if it can't be improved, just live with it.
With the signal tracer, the only spot I find egregious levels of hiss (while turning up the volume) is at the ground side of the channel mix resistors, and at a bit lower level, back to the .1uf coupling cap off v4. All these components are new, and I tried swapping those capacitors.
Listening at points earlier in the signal chain the hiss seems so low I can barely register it, but I'm not sure I'm doing this right. At this point I have tried many different tubes, grounding schemes, and components, so I just want to focus on tracing.
Is the high level of hiss at the PI inevitable due to the level of gain it has on it? I have a 12at7 in there and have even tried a 12au7. I have seen many comments that it's a bad idea to use a 12au7 in the PI, but is it worse than installing a master volume?
Would appreciate any tips on how to search for the source of hiss (given all components here are new and high quality).
