Trouble With Violin-Maker’s Clamps
Discussion in 'The DIY Tool Shed' started by Stringbanger, Apr 21, 2018.
  1. Stringbanger
    Stringbanger Telefied Ad Free Member
    West O' Philly, PA
    Most guitar builders know what these are, especially the acoustic builders. (Sorry that it’s upside down).
    I’m trying to use contact cement to glue the cork cushion to the wood disc, but it’s not holding. The contact cement says okay for porous surfaces, but I’m not having much luck. Any suggestions would be welcomed. I think the wood is oak dowel.
  2. guitarbuilder
    Use double sided tape. Carpet or Duct.
    Stringbanger likes this.
  3. jamorudd
    jamorudd Tele-Afflicted
    Oklahoma City, OK
    I used titebond on mine, as I recall, and they’ve held up fine for 2 years now.
  4. Frodebro
    Seattle
    End grain is a bugger to get things to adhere to, maybe use yellow glue to fill the pores, then once it's dry try the contact cement again.
  5. Crafty Fox
    Crafty Fox Tele-Afflicted
    Perth Australia
    I used contact glue, cork onto MDF, then cut my discs using a carpenters hole saw.
    The handles were spindles that I'd cut the ends off, drilled 10mm hole at one end to epoxy glue the threaded rod into.
    They've lasted easily 5 years now with no sign of deterioration.
    Axis29, jvin248 and Stringbanger like this.
  6. Jupiter
    Jupiter Telefied Ad Free Member
    Osaka, Japan
    I also used Titebond Original. No issues, though they haven't seen a whole lot of action.
  7. physicsteach
    physicsteach TDPRI Member
    Evanston, IL
    Shoe goo? liquid nails?
  8. Stringbanger
    West O' Philly, PA
    Thanks for the responses thus far guys. Now I might be a step closer to finishing this dulcimer that I started 5 years ago.:D
