fishyguy192
am trying to put new caps in a teisco checkmate that I just got. It had been messed with a little in the past so I figured I would get the power section back to spec. I replaced the 100mf/250v caps with 100mf/350v caps and the 20mf/500v caps with 22mf/500v. I turned the amp on to check voltages for the caps and I was getting 320v on the first cap and then the second was reading 560v which is obviously very high. I also am not getting any output. I have obviously messed something up but from the schematic it looks like everything is following where it should be. The caps polarity seems correct but I am not sure if it is actually good. I am wondering if anyone with a keen eye could look at a picture of what I have and compare it to the schematic. Also ignore the red written in caps from the schematic picture. One red wire from the transformer goes to the 4.7k (5k on the schematic) resistor and then to the 100mf filter cap which leads to the negative side of the next 100mf cap. The other red wire goes to the positive of one diode and the negative of another diode. Red goes to positive of one diode then through diode and negative end goes to the next 100mf cap.
Just confused why I’m getting really strange voltage and no output.
I made this post on the glowing tube forum thread but didn’t realize there was also a tech thread. I am going to try to do some more voltage readings straight from the transformer tomorrow to see if I have something messed up from there.
