Hi all!
So, before opting to swap the neck pickup in my 1973 std. Tele, I wanted to try the mod where you bypass the tonepot on the neck pickup, as it supposedly leaves it more "open" and bright.
Step 1 was supposed to be: remove the short wire from the the vol pot lug to the tone pot lug.
Step 2: Attach new wire from the same tone pot lug and connect at the same switch lug where the bridge pup attaches.
Step one I didn't have to do, as the was no wire the. The cap i attached between the two, just like the diagram suggests that it should be. Be aware that, as fellow tdpri'ers have helped me establish in my thread in the vintage forum, this guitar already has had some work done by a previous owner, and the pots have been changed from 1meg to 250K.
I did step 2, and now the bridge and middle position are completly silent, and only the neck position works - and the tone control is still active.
Removed the wire, and everything was back to normal. Tried it again - maybe my rookie soldering skills were betrying me even more than I was expecting. Same problem: Only the neck pickup now works, and the tone pot is still active... So I removed the wire again, and the guitar is again back to normal. But what is wrong? I went over the wires, one by one, and everything is according to the diagram, except one thing: The ground wire (black) from the jack is not soldered to the top of the vol pot, as the diagram says, but it is soldered to that exact tone pot lug that I was trying to connect the new wire to. The lug is actually bend towards the pot, and there is so much solder, that it's had for me to se if the ground wire from the jack is touching the lug. Could this be the problem? I'm afraid to just try out stuff, as I basically have no idea what I'm doing what so ever. By only experience with anything in this department is this one time, in 2009, where I actually wired a strat pickguard from scratch, jack, pickups, everything, following a diagram. But I have absolutely no idea why this goes here and that goes there...
Can anyone offer some advice? Has some kind of mod been made, since there was no wire between the tone pot and the vol pot, and since the ground wire goes to the tone pot? Or is it simply a mistake someone made? Or maybe it doesn't matter?
This picture is from before I started messing with it. Above my thumb you can see where the ground wire is attached...To the left, where the yellow wire connects to the switch is where I connected the new wire - together with the yellow from the bridge pickup
