Tres Recogida Especial
Discussion in 'Tele Home Depot' started by Mike Simpson, Jan 30, 2010.
  1. Mike Simpson
    Gilbert, AZ (PHX)
    Maricopa... I guess you would know since you play a guitar with 4 pickups...
    Randy, I sold the National Tele a while back. Different pickups sound better at different heights. The guitar sounded fine but I wasn't playing it anymore since I built the first pinecaster... Yeah I will post a sound file when it's done.
  2. Maricopa
    Maricopa Friend of Leo's
    Phx, AZ
    D'oh! :D
  3. boris bubbanov
    New Orleans, LA + in the
    This looks great, Mike!
    Don't mean to be a troublemaker, but I kinda like the proto pickguard (with no coverage over the horn) shown in post #47.
    If you don't use that shape soon, maybe I will! :D
  4. Mike Simpson
    Gilbert, AZ (PHX)
    Boris, do you mean this shape here?
  5. Mike Simpson
    Gilbert, AZ (PHX)
    I pretty much finished this 3 P-90 Tele tonight except for adjusting the pickup height.
  6. Ronsonic
    Ronsonic Tele-Afflicted
    Sunny Tampa, Florida
    With that pickplate and P90s it's like there's some SG Special DNA in that guitar.
  7. boris bubbanov
    It looks great, but I like the one envisioned by the white paper template in post # 47, except with the pickguard over the horn itself deleted as on a Thinline pickguard.
  8. Mike Simpson
    Gilbert, AZ (PHX)
    Boris, Do you mean to cut off the horn the same shape as the pickguard?
    Sort of a Macaferi cutaway?
  9. boris bubbanov
    The body is fine. I just like the white paper pattern shown in # 47 with the horn portion of the pickguard removed as a pickguard shape, leaving the body as it is.
    I dunno what a Macaferi cutaway is but I assume that is like a Rice Osprey or a Soloway Swan? No, I don't see that.
  10. Mike Simpson
    Gilbert, AZ (PHX)
    Here is a picture of this guitar all done. I will work on posting a sound file next week.
    Tres Recogida Especial (pronounced recoheeda means 3 pickup special)
    Pine body, I made the stainless steel control plate, neck plate and B/W/B pickguard, Allparts TMO-fat neck with Planet Waves locking tuners, brass ferrule bar, 5 way switch, push pull tone pot and a Big D Varitone. The finish is ReRanch Shoreline Gold nitro and Behlens clear nitro with a couple of drops of honey amber transtint.
  11. Mike Simpson
    Gilbert, AZ (PHX)
    I took this guitar out to the blues jam last night and it has some great sounds and tonal variety.
  12. hackworth1
    hackworth1 Friend of Leo's Vendor Member
    Volusia County, Florida
    Looks fantastic. Excellent work. Did you use two neck pickups and one bridge pickup or two bridge pickups and one neck pickup?
  13. Mike Simpson
    Gilbert, AZ (PHX)
    I bought a N & B set from Eastwood and the middle I bought from the TDPRI classifieds that was sold as a "Gibson P-90" and I don't know what it was originally made for.
  14. hackworth1
    Thanks. Do you still have the push pull switch for the bridge pickup in the circuit? When you get around to it, have you a diagram of your wiring layout?
  15. Mike Simpson
    Gilbert, AZ (PHX)
    Yes it has a push pul pot on the tone so when the 5 way is in position 1 or 2 you can add the bridge by pulling up the tone pot knob. This adds the N+B and N+M+B to the standard 5 way switch so there are 7 pickup combinations possible. It also has a 5 position varitone switch and the tone pot still functions when the varitone is selected and the varitone has a 6th position that bypasses the varitone.
    Here is my wiring thread and hand drawn diagram as well as a similar diagram by Deaf Eddie that is the same except he switches the neck pickup instead of the bridge.
    http://www.tdpri.com/forum/just-pickups/196558-wiring-diagram-3-p-90s.html
  16. 2Wheels
    2Wheels TDPRI Member
    Aledo, TX
    Mike,
    I have to say in front of all the Tele-gods and mankind...THIS ONE is the complete package. Color and trim combo works perfectly together and is evident of a well thought out and executed build. It is 'crisp' and super clean.
    Keep them coming please. Don't hold back - get busy with it! I'm thinking you need to build me one before too long....
    Thanks for sharing your talent.
  17. Mike Simpson
    Gilbert, AZ (PHX)
    Well to me no guitar is complete without it's own strap that stays with that guitar. I usually make them fitted "just for me" so they don't need any buckles or extra adjustment holes. I decided this guitar should have a "vintage" looking skinny strap with a padded slide. I elected to not do any tooling and just put an outline groove on the strap and I used white stitching because the pickguard is B/W/B.
    Here is the leather for the pad cut out and I bought a belt blank from Tandy to use for the strap so I could get 1 piece that long with no seams or splices. I wetted the leather and skieved off the corners to round the edges.
  18. Mike Simpson
    Gilbert, AZ (PHX)
    Once I had the out line groove on the strap and the stitching groove on the pad with the stitch locations marked with a star wheel I dyed the leather black with USMC black dye.
  19. Mike Simpson
    Gilbert, AZ (PHX)
    Then I dyed the back of the leather on the sheepskin black in case it was visible through the strap slot and then I glued the sheepskin to the pad leather with elmers rubber cement. The rubber cement remains flexible and holds the sheepskin in place while I punch the holes with an awl and stitch the pad on.
  20. Mike Simpson
    Gilbert, AZ (PHX)
    Then I stitched the sheepskin on with white thread (remember the pickguard is B/W/B) and used some Pecards leather dressing on all the leather to keep it moist and flexible.
