Tres Recogida Especial
Discussion in 'Tele Home Depot' started by Mike Simpson, Jan 30, 2010.
  1. Mike Simpson
    Gilbert, AZ (PHX)
    Well... Fender had there La Cabronita Especial...
    Here the Simpson... Tres Recogida Especial (Three Pickup Special)
    This one started the same way as my Palletcaster from last years $100 challenge. The body is made from 4 pieces of pine 2x4's that was a shipping pallet. I had it routed for 2 P-90's and then decided that was not "Especial" enough... so I added a 3rd P-90 in the middle. I thought I was doing something different until I searched for a wiring diagram for 3 P-90's and I found a youtube video by Mojocaster showing his Tom Anderson Cobra that is made with the same pickup configuration.
    I asked about how to wire it in this thread.
    http://www.tdpri.com/forum/just-pickups/196558-wiring-diagram-3-p-90s.html
    Here is the routed body and the Wilkinson half bridge I am going to use.
    It started out like this before I added the middle pickup route.
    I made my own "tone block" string anchor out of 3/8" x 3/4 brass.
  2. Maricopa
    Maricopa Friend of Leo's
    Phx, AZ
    Only Tres pick-em ups? My Quatro Tiescos and I laugh in your general direction! ;)
  3. hackworth1
    hackworth1 Friend of Leo's Vendor Member
    Volusia County, Florida
    That's a nice and thick tone block. I think I'll make one. More solid tone and you don't have to buy string ferrules. Ron Kirn also has a triple P-90 build on this site.
    I have two P-90's on my first build. I like them very much. A third pickup is often located exactly where the 1/4 harmonic is located on a guitar.
    That spot could be a better place for the rhythm pickup on any build.
  4. Hollmanp90
    Hollmanp90 Tele-Afflicted
    Hamilton County
    Very cool 3 x P90 !!!
  5. Mike Simpson
    Gilbert, AZ (PHX)
    I spent some time tonight making a 3 knob control plate and a matching neck plate out of stainless steel. I now officially do not like making parts out of stainless.
  6. guitarbuilder
    Lookin' good there Mike. The no challenge challenge is on!
  7. TwinReverb
    TwinReverb Tele-Meister
    The Netherlands
    I love a nice 3 P-90 tele.
    I have mine wired like a Strat except for one position. I have bridge and neck instead of neck and middle.
    Enjoy!
    Erik
  8. Mike Simpson
    Gilbert, AZ (PHX)
    Erik, Do you have a position that all 3 are on? I say a video on youtube by Mojocaster and he has a Tom Anderson guitar with 3 P-90's and he uses a 5 way switch and a push pull pot to allow any combination of the pickups.
    Here ia a link http://www.youtube.com/watch?v=M2x9VYLzjAY
  9. TwinReverb
    The Netherlands
    Hi Mike,
    I saw the vid by Mojocaster. Nice sounding axe.
    I don't have a push pull switch to activate all 3 pickups.
    The guitar is already very versatile with 5 great sounding options.
    I had a Fat-o-caster switch in a Strat once but I have gone back to "basics". :lol:But frankly I don't really care for the all-3-on option. IMO overkill.
    I do have a pull switch on my Micawber clone to activate the single coil option of the Fralin Unbucker in the neck position. Again 5 pickup options that way.
    Erik
  10. helectrix
    helectrix Tele-Meister
    Belgium
    nice one!
    here's my 3 P90 strat, was my nr 1 for years. tone monster ... :)
  11. boris bubbanov
    New Orleans, LA + in the
    I can appreciate that. ;)
    I've been making some things out of brass. Make it yourself, so you can fix it when it begins to corrode.
    Project looks very cool, so far! :cool:
  12. Mark-00255
    Mark-00255 Tele-Holic
    South of Seattle, WA
    Looks cool, Mike! What kinda P-90s will you be using?
  13. Mike Simpson
    Gilbert, AZ (PHX)
    Mark, Two of the pickups I have are from myrareguitars.com (eastwood) and one I bought in the TDPRI classified as a "used Gibson P-90". I am still decining on the wiring... I might add a varitone to this one.
    Helectrix, How is your strat wired? I see it only has 2 pots.
    I need to make up my mind on the finish... I am considering sonic or daphne blue, shoreline gold or copper metalflake.
    I just about finished the stainless neck plate and 3 hole control plate today.
  14. helectrix
    Belgium
    for me simplicity rules, 1 V, 1 T for all pups.
    and a strat 5 way switch
    All 3 Gibsons but I added the middle 6 years later, and it sounds completely different from the other two (as in: not as good, not as punchy). I always used my vibrolux with this strat. on a Bassman it was too muddy... My P90 tele works great on a Bassman though.
  15. Mike Simpson
    Gilbert, AZ (PHX)
    The 3 pot control plate I made from stainless is 1" onger than a standard Tele control plate so I extended the control plate route to the rear to match the longer plate. I finished polishing the control plate, stainless neck plate and brass ferrule "tone" block. I also did the 1/8" roundover all around the body and have it almost ready to start the finish.
  16. guitarbuilder
    Nice looking stuff.
  17. tuuur
    tuuur Friend of Leo's
    the Netherlands
    And another great build thread! Looking great so far!
  18. guitarminator
    guitarminator Banned
    warwick RI
    how did you fab the "tone bar"?
  19. Mike Simpson
    Gilbert, AZ (PHX)
    I scribed a line down the center of the piece of brass. I find it easier to cut it off the foot long bar after it is drilled. I laid my bridge on top of the bar and lined up the string through holes with the center line and then scribed the location of each hole. First I centerpunched all the locations I marked and then drilled the smaller holes with my $39 harbor freight drill press. When I drill the larger countersink to allow the ball end of the string to fit in like a ferrule I set the stop on the drill press so it would only travel to a depth a little greater than the ball end. When I have the holes all drilled I cut it off the end of the long bar which makes a great handle up to that point. I drilled a 3/4" hole in a piece of MDF with a forstner bit and I used that citcle to scribe the radius on each end of the bar. I rounded the ends using the round disc on the side of my belt sander and cleaned it up with a file and some fine sandpaper and a 3m pad with some wd40.. It is more polished than it looks in the photos.
  20. Mike Simpson
    Gilbert, AZ (PHX)
    Here it is tonight... test fitting everything. I think I am leaning towards surf green on this one. I need to decide on a pickguard shape...
    The Allparts TMO-fat neck I bought here in the classifieds from Rob DiStefano that came with some planet waves locking tuners.
    I put the two outside E strings on tonight to make sure everything lined up.
