Tremolux Head Build
Discussion in 'Shock Brother's DIY Amps' started by BigDaddy23, Jan 17, 2019.
  1. BigDaddy23
    BigDaddy23 Tele-Meister
    Heres a few pics of my Tremolux build. It’s based on the 5e9a schematic with a tweak to the second input for more gain.
    I bent and drilled the chassis myself from 1.5mm aluminium (a bit of a nightmare!!) polished the front and back panels and used my custom decals covered with about 10 coats of clear lacquer. I made the cabinet from birch ply and went with a bit of a vintage look with the tolex and cloth combo. The Ace logo is 3D printed after faffing about in Adobe Illustrator and CAD. I printed them in black, sprayed them silver then wet/dry sanded and polished the letters back to black. Clear coat thereafter.....I like them!
    I might add that I’m actually a bass player .
  2. trouserpress
    trouserpress Tele-Holic
    Leipzig
    Wow! How very nice that is!
    Please tell us more about how the tone control cirquit works and what the weight is. How would you describe the tones?
  3. BigDaddy23
    Thanks mate!
    The only difference is I used a 680nf in place of the 500 bright cap and the marshall style input. The head weighs about 4kg. Sound wise, there is a noticable boost between the 2 inputs with earlier breakup in the higher gain channel. With an A/B pedal, you can switch between the 2......a poor man's boost switch!
    Compared to the 5e3, the low end/low mids are way tighter. I'll get one of the guitarists to record a few sound grabs. Single coils and p90's both sound full to my ear.
    JustABluesGuy and trouserpress like this.
  4. Nickfl
    Nickfl Tele-Afflicted
    Nice work. That 3D printed logo is especially impressive!
  5. flyswatter
    flyswatter Friend of Leo's
    Quebec
    Very nice! You're a brave man bending your own chassis. I pride myself as a DIY type of guy, but I tried that once and gave up in despair. Good work all around on this build.
  6. robrob
    United States
    Beautiful work.
  7. BigDaddy23
    Thanks - the engineering blokes at work have a big pan brake and guillotine which they let me use. The little 90deg lip bends limited how tall I could make the front face but I think it worked OK. Everything is easier with the right tools! Driling the holes was more difficult. I had to make 3 block spacers when drilling the faces to stop the aluminium distorting.....I used 2 of them as end blocks. They have 6mm T Nuts through them to allow securing of the chassis through the sides of the cabinet. You can see them under the shielded cable in the 2nd pic.
    I should take some better pics of the finished product
  8. flyswatter
    Quebec
    That explains why they look so good. I tried doing it the Uncle Doug way -- he has a vid where he successfully makes a chassis using a sheet of steel, a sledgehammer, and some 2X4s. But my results were -- let's say -- not worthy of comment.
  9. BigDaddy23
    Haha - Ive seen that vid. He has been a wealth of knowledge in my journey thus far. Given how well he restores old cars etc, I'm not surprised that he can make "a silk purse from a pigs ear!!"
  10. BigDaddy23
    Finally got round to building a small cab for this head (and the Marshall 18w I’ve started building ). I have a 10” 60w British Invasion WGS speaker for it.
    The grill cloth will be the same as the head face with the silver piping perimeter. That will happen during the week sometime. I also need to grab some more cup washers for the lower panel as per the top.
    teletimetx, PaceAmps, robrob and 2 others like this.
  11. BigDaddy23
    Should have mentioned that this will primarily be used for recording and small gigs.
  12. Michael A.
    Michael A. Tele-Afflicted Ad Free Member
    Virginia Beach, VA
    Beautiful build, you should be immensely proud! What a gem!
    BigDaddy23 likes this.
  13. BigDaddy23
    So I gave this a run today - cab has a WGS British Invasion Retro 10.
    I found the tone control a little wooly and I'd like to get a bit more treble response on the tone knob. It is certainly more noticable in Channel 1 (lower gain) but is also present in Channel 2 but less so. I tried it with a couple different guitars with similar results. See above pics of the board and layout for reference. Note I built it left to Right (ie mirror image) compared to the layout diagram above.
    The tone control is as per the fender layout above with 1meg pot but with a 680pf bright cap in between the tone and vol 2 pot and the 0047 tone cap. Can anyone suggest a way to get a bit more high end? I was thinking about changing the bright cap to the original 500pf, putting the 680pf as the tone cap and dropping the value of the large 0.1uf coupling cap in V1B to a smaller value eg 0.022uf.
    Any thoughts?
  14. robrob
    United States
    I'd try another speaker. The circuit itself should have plenty of highs.
  15. BigDaddy23
    Any recommendations from the WGS 10” line? Perhaps something from the American Vintage?
  16. BigDaddy23
    I went ahead and ordered a WGS American Vintage G10C. This should provide a much brighter sound for this head.
    The Retro 10 should be a better match to the Marshall 18w head I am building at the moment. It's a 5min job to swap the speaker so I'm not planning on building another cab!
  17. robrob
    United States
    The 10" Veteran is nice but it's rated at only 20 watts. Two of them in a cab would be perfect though. If you must go with a single 10" then their G10C would be the way to go to add highs.
    Edit: I see your previous post. Good choice.
  18. BigDaddy23
    Thanks Rob.
    This amp is fabulous...ch 1 Tremolux for great cleans, get the volume up for some nice grit. Ch 2 for big OD and lead tones. And then there's the tremolo :eek:. I'll post some recordings once we get in the studio with it.
    robrob likes this.
  19. Greg_L
    Greg_L Tele-Holic
    That is bad ass. Truly great work.
  20. D'tar
    D'tar Tele-Afflicted
    WNY
    Sweet! That badge is Ace!
