Tremolo too high after string change
Discussion in 'Stratocaster Discussion Forum' started by dogfootblues, Feb 18, 2020.
  1. dogfootblues
    dogfootblues Tele-Afflicted
    New Jersey
    Hey guys. I have my first Stratocaster over here. Mainly a tele man with 5 always waiting to be played. The Strat came with 9 gauge strings. I switched to 10 gauge and the bridge is raised now. My question is this.
    How do I lower the bride now that I put heavier gauge strings on? Is it as simple as tightening the spring in the back?
    Any help is good help. Thank you boys.
    Mike.
    Sent from my iPad using Tapatalk
  2. GuitLoop
    GuitLoop Tele-Meister
    Pa
    Open the panel on the back of your strats body and adjust the screws that hold the plate at the end of the springs. If that doesn't provide enough adjustment you can add or remove springs or change springs...springs with different amounts of tension are available.
  3. pondcaster
    pondcaster Poster Extraordinaire
    Tryon, NC
    Adding another spring will probably work but I just put a stack of old pennies in there to lower. Usually 5 to 8 cents does the trick for my Strats.
    dogfootblues likes this.
  4. Obsessed
    Montana
    This is the correct method for adjusting. Loosen the strings first before each tweak in the back, then retune. Repeat as required. Thus may take some time, but once you get it right, it will usually stay there.
  5. dogfootblues
    New Jersey
    Thank you gentleman. Been away for a few years but always had great help from everyone in this place.
    Thanks again.
    Mike.
    Fendereedo and lineboat like this.
  6. Lobomov
    Lobomov Friend of Leo's
    Europa
    Yes .. Screw the claw that holds the springs further into the body and you're done.
    Jlwctn, dogfootblues and Marc Morfei like this.
  7. dan40
    dan40 Tele-Afflicted
    Richmond Va
    This method from the Fender Custom shop is very easy to use and works perfectly every time.
    Wound_Up, Fendereedo and dogfootblues like this.
  8. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    HNGD !
    sent you a PM
  9. Fendereedo
    Fendereedo Poster Extraordinaire
    Some good advice here.
