Tremolo, no tap tempo
Discussion in 'The Stomp Box' started by Bergy, Feb 27, 2019.
  1. Bergy
    Bergy Tele-Holic
    Denver
    Recently picked up a Boss TR2 unit. It sounds pretty good so I added it to the pedalboard. When it came time to use it on stage, I tried 3 times to sync it up to the tempo of a tune before I gave up. Then something happened I hadn’t even thought of....the drummer subconsciously matched tempos with my darn tremolo pedal. It really bugged me that a stompbox was influencing our tempos. I don’t want that to happen, seems bass ackwards.
    Is there any hope of getting better syncing it up with the potentiometers, or should I just scrap it and get something like a TC Pipeline that has a tap tempo?
  2. ScribbleSomething
    ScribbleSomething Tele-Holic
    San Antonio
    That’s a discussion for you and your drummer. It depends on how many songs have critical tremelo timing.
    I come from the school that says tremolo doesn’t have to and probably shouldn’t line up to the beat. But I’m not trying to pull off “how soon is now?”
    In the old days the drummer would adjust if he needed. That’s why the song above starts with the tremelo guitar and most of the U2 songs that had a very specific delay time also lead in with guitar.
    But it sounds like you’d be happier with a tap.
    mitchfinck and noah330 like this.
  3. Junkyard Dog
    Junkyard Dog Tele-Afflicted
    I suggest that before you get on stage (e.g. at home, etc.) try out various adjustments to the "rate" knob, and then make note of each setting...i.e. set rate at 12:00 for Born on the Bayou, 10:00 for Crimson & Clover, etc. You also could put painters tape or label tape or similar on the case to mark knob positions.
  4. ICTRock
    ICTRock Tele-Afflicted
    Tampa,FL
    reread your post and ask yourself "What would Link Wray do?"
    bo likes this.
  5. SixStringSlinger
    SixStringSlinger Friend of Leo's Silver Supporter
    Space
    To get to the bottom line, he's saying to stick a pencil in your tremolo.
  6. telel6s
    telel6s Tele-Afflicted
    Northern Virginia
    On the one hand, be happy that you play with a drummer who is actually listening to others in the band.
    My Trem has always been built into my Fender amps so I set a speed & depth and just play. The knob has ten numbers but I think of it as four settings: really slow, slow, medium, fast.
    But I am really intrigued with a lot of the newer trem pedals that can do tap tempo, doubling, six or so wave shapes, or change the ramp-up/ramp-down speed independently of each other. I've heard some really cool stuff on demos that is both classic and modern at the same time.
    As for replacing your BOSS trem, on how many songs is this timing thing an issue? If it's just one song I'd figure out the proper settings (a dot of white-out or tape to mark it) and then be sure the drummer is always on the correct tempo (pretty much what Junkyard Dog said above). If it's a problem on multiple songs or you would like to get the trem tempo synced up more often then maybe a new pedal is in your future.
    ScribbleSomething and noah330 like this.
  7. Lord_Ingipz
    Lord_Ingipz Tele-Meister
    Cicero, IL
    Had the stereo hardwire trem/rotary that had a tap tempo feature that I never used or an optional footswitch. Gives you all sorts of sounds.
  8. sclitheroe
    sclitheroe Tele-Meister Ad Free + Supporter
    Hamilton, Ontario
    This is awesome
