Trem pedal recommendations?
Discussion in 'The Stomp Box' started by srblue5, Jun 12, 2021.
  1. Festofish
    Festofish Tele-Afflicted Silver Supporter
    Grand Rapids, MI
    If I could buy the world one pedal it would be an EHX Stereo Pulsar. Easy as pie with way more versatility than it looks. However...it may not be for the OP. One of the funnest pedals I’ve owned and it’s a trem!
    TeleCarlos and northernguitar like this.
  2. Hoodster
    Hoodster Friend of Leo's
    Oregon
    He doesn’t have to mark it off his list just because you don’t like it. There are at least two of us on this thread that think it is a very fine pedal, particularly the bias tremolo which is what the original poster is after.
    The Tre-Verb sounds exactly like my former Princeton’s reverb and trem. My only quibble with it is I wish it had a hall reverb instead of two spring settings. Redundant for me.
  3. Tele-beeb
    Tele-beeb Friend of Leo's
    The Bluegrass
    Likely any of the recommendations would answer that… however, it’s when you want the trem pedal that life takes on color… then it’s “welcome to the rabbit hole.”
  4. Guitarteach
    Boss TR-2 for me... got a useful waveshape control and volume drop was fixed in newer versions,
  5. El Marin
    El Marin Friend of Leo's
    Spaniard in Pärnu, Estonia, EU
    I went almost the same path and finish with the same... Keeley modified TR-2
    pippoman likes this.
  6. RobSzat
    RobSzat TDPRI Member
    Brigantine
    Milkman F Stop. Dear simple, sounds great, has really nice amp style reverb as well. It won’t be coming off my board
  7. bananafist
    bananafist Tele-Meister
    Cornwall UK
    Have owned SFTR, DR, both had the optical on/off type trem, ok, but.....then I got a PR and a Vibroverb reissue, different early Fender vibrato! The nearest pedal I've tried to the PR trem is the Swamp Thang, and maybe the Strymon, but nothing is quite as cool as the Fender PR and Vibroverb trem. Good luck.
  8. wattsupnow
    wattsupnow TDPRI Member
    wheeling
    I will second the Nobels recommendation. I really like mine - it sounds earthy like a tube based one in an old amp!
    Edgebound and G.Rotten like this.
  9. WWLaidback
    WWLaidback TDPRI Member
    Sparta, NC
    Wampler pedals have impressed me in general. Priced around $150, the Latitude trem comes with tap-tempo:
  10. atchdav
    atchdav TDPRI Member
    Prospect Bay, NS
    I also own a Quaverato and second the above sentiments; a great trem at an affordable price.
    I have a BOSS TR-2 too. It also sounds fantastic. Can't go wrong with BOSS.
    TokyoPortrait likes this.
  11. Coxon Boy
    Coxon Boy TDPRI Member
    Edinburgh, Scotland
    Mojo Hand FX Bayou. Excellent amp-style tremolo, analog, blinking LED in time with the trem, level control to compensate for volume drop which is also capable of a huge boost if required
  12. G.Rotten
    G.Rotten Tele-Afflicted
    CoolsVille
    Exactly!!! Great way to describe it.
  13. Muadzin
    Muadzin Tele-Meister
    Netherlands
    When I still used pedals Culturejam's Shoot the Moon tremelo, a simplified DIY version of the 4ms Tremelus Lune, was all the tremelo I needed. Chop or triangle (mostly chop), depth and speed are the only controls I need.
  14. Blackshadowrider
    Blackshadowrider TDPRI Member
    Detroit
    I think for the price and pedal trem you cannot go wrong with the Boss TR. I really am interested on buying a Strymon Flint but at $300 it is an expensive pedal cost for me but the three trem options offer some good options and then you also get three reverbs. I am a 65 Fender DRRI user and my amp trem as gotten noisy and unusable, my be the tube I do not know yet. Amp repairs are also expensive.
    Maguchi likes this.
  15. donnyrocker
    donnyrocker TDPRI Member Silver Supporter
    Denver, Indiana (the little one)
    Using the one in my Twin, erroneous dubbed "Vibrato."
    I have an older Fulltone Supa-Trem that is on the noisy side.
    Kmise: $10 used, gets the job done. Danelectro Tuna Melt sounds good.
  16. KW1977
    KW1977 Tele-Meister
    Virginia
    I have a Subdecay Vagabond Tremolo that nails every need I could possibly ever have in a tremolo. Harmonic, bias, envelope control, volume knob, plus it sounds incredible. I’m glad I didn’t waste my money trying/buying any others first.
  17. Benditslow
    Benditslow TDPRI Member
    St.Louis Mo. USA
    Fulltone supa-trem. I’ve tried a bunch & the supa-trem all ways finds its way back to my board.
  18. Kansas
    Kansas TDPRI Member
    Topeka Kansas
    I needed a trem for a few tunes we are doing. I bought the Ibanez mini one. It’s been perfect. I used it live for the first time Saturday night and that was about the only thing I was 100% happy with. Small and cheap too!
  19. pippoman
    pippoman Tele-Meister Silver Supporter
    Memphis
    I second what chiogtr said. I haven’t tried all the trem pedals out there, but of the ones I’ve tried, none of them worked better than my Boss TR2, some not as well, and BOSS’ quality is impeccable. Plus, all BOSS pedals have a nice buffer built in so you won’t need to buy a separate pedal for that. For that reason alone it’s good to have a couple of them in your chain. I’m done wit the trem pedal search.
    To me, trem should be a simple thing to work with and the TR2 is just that.
  20. hotdotdog
    hotdotdog TDPRI Member
    glendora ca
    I am a tremolo junkie and have owned pretty much every tremolo pedal there is. (been gigging over 50 years) The best PRRI type sounding is a Modified Boss TR2. There are a couple outfits modifying them. One is Alchemy Audio and they put a boost circuit in it so the volume doesn't drop below your non-tremolo volume and they put a circuit in the lets the LED flash in time with the tempo when it is disengaged so you can see what speed it's pulsing at. The best part though is the sound. It's a legitimate Fender sound. You can find them on reverb.com https://reverb.com/item/38895819-boss-tr-2-tremolo
    Maguchi and jays0n like this.
