treble midlle bass for 5e3
Discussion in 'Shock Brother's DIY Amps' started by Airline-Olie, Jul 7, 2009.
  1. Airline-Olie
    Airline-Olie TDPRI Member
    london
  2. rolilohse
    rolilohse TDPRI Member
    Hamburg/Germany
    Olie,
    of course you can add TMB to a 5e3, the question is if it's still a 5e3? You will loose a lot of gain in these controls and so the amp will loose a lot of its character. Many amps with TMB controls (Tweed Bassman, Marshalls) use a kathode follower to feed the tonestack to compensate the gain loss.
    If you want to build an 5e3 stick to the old schematics and layouts - the beauty of these old designs lays in its simplicity.
    Just my 2 cent.
    Roland
  3. Airline-Olie
    london
    I didn't realise it would change the tone so much thanks for your help Ill just keep it normal then I want my 5e3 to sound like a 5e3
  4. JohnnyCrash
    JohnnyCrash Doctor of Teleocity Gold Supporter
    Fullerton, CA
    Adding a tonestack will affect the front end gain. To compensate for gain loss Leo eventually ended up with plate fed tonestacks, and the classic Marshall uses cathode follower tonestack.
    The typical Volume/Tone setup per channel is probably easier to pull off with few issues.
  5. petebradt
    petebradt Former Member
    Niner Country
    Agree with Johnny. A 5E3 doesn't need that complexity in the tone stack.
