Transformers for Vibro-Champ clone?
Discussion in 'Shock Brother's DIY Amps' started by ArcticWhite, Aug 9, 2019.
  1. ArcticWhite
    ArcticWhite Tele-Holic
    Portland Oregon
    I'm hoping to build a blackface Vibro-Champ and need to pick a set of transformers from my pile of Hammond amps. I have available iron from the following:
    AO-35
    AO-44
    AO-29
    AO-43
    None of these are single ended amps like the AA764 is. Can I use any of them?
  2. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Your AO35 looks like it's got ballpark power figures. The Champ's B+ is a little higher but subtract one EL84 I reckon you'll be round where you need to.
    You need a single ended output trans but they're cheap. Any radio item using 6V6 or 6BQ5/EL84 would work.
    TequilaCaster and ArcticWhite like this.
  3. ArcticWhite
    Portland Oregon
    That's a great idea!
    I'm morally opposed to buying new transformers since there are basically free ones all over the place. I'll start looking for a radio immediately.
  4. Dacious
    Godzone
    You could use half the output transformer. Just use centre and outside tap. But that would probably be great for a Tweed Deluxe output, Vox AC10/15 build.
    ArcticWhite likes this.
  5. ArcticWhite
    Portland Oregon
    I'm planning a small amp this time. I just sold a Tweed Deluxe, and I have a couple of 15 to 18 watt amps.
  6. ArcticWhite
    Portland Oregon
    Is that safe to do? I was told that single ended OT have thicker wire, and and air gap...
