FXBDM 1832
I have a few output transformers for which I have very little information (old radio pulls). I understand that the way to go about finding the windings ratio is to measure the voltage ratio when supplying AC to one side of the windings.
Most sources I have seen online suggest using the 5v or 6.3v windings from the power transformer. Of course, this isn’t a portable solution and you need to have an unused PT lying around (I do have one, but it’s wired in to the radio and I don’t want to play around with the old leads too much, sometimes they are brittle)
I was thinking more along the lines of generating a signal from a phone app, and then amplifying this through a diy LM386 amp. Would that work? Or am I better off using the PT trick?
Also, do I need to have a load connected on both sides of the OPT?
