Transformer identification, or mapping
Discussion in 'Shock Brother's DIY Amps' started by ArcticWhite, Aug 11, 2019.
  1. ArcticWhite
    ArcticWhite Tele-Holic
    Portland Oregon
    Found this little guy in my scrap pile.
    I pulled it out of a Hammond chord organ a while back but not sure which one.
    I Googled the numbers but came up empty.
    Is it a single ended OT? Will it work for a Vibro-Champ build?
    Wires are black red blue green.
    Snfoilhat likes this.
  2. peteb
    peteb Friend of Leo's
    Cascadia
    It appears to be that
    What is the resistance red to blue? Black to green?
  3. ArcticWhite
    Portland Oregon
    Red to blue 150 ohms.
    Black to green 1.2 ohms.
  4. Snfoilhat
    Snfoilhat Tele-Afflicted
    Oakland, CA
    Next, just apply a known AC voltage across the secondaries, remeasure the 'known' voltage across the secondaries because especially w/ single-ended OTs there seems to me to sometimes be a drop I don't understand but has been discussed a little in Shock Brothers. I like to use the heater voltage from a PT I'm confident in and is safely running on the bench, but other voltage sources are available.
    Then measure the VAC across the primaries and set up a ratio Pvac:Svac
    Reduce the ratio so that the Svac is 1 (Pvac/Svac : Svac/Svac)
    Square both sides
    Then make a little table by multiplying both sides by 2 ohms, 4 ohms, 8 ohms, 16 ohms, and the P will be the primary impedance for whatever the S (2 or 4 or 6 or 8 or 16) is loaded with.
    peteb, ArcticWhite and Nickfl like this.
  5. ArcticWhite
    Portland Oregon
    I'm not sure I follow your math all the way.
    P Vac = 140, with SVac = 6.4
    P/S = 21.9
    21.9 : 1
    "Reduce the ratio so that the Svac is 1 (Pvac/Svac : Svac/Svac)
    Square both sides"
    Is that what you meant?
    480:1
    Square of 1 is 1.
    Snfoilhat and peteb like this.
  6. peteb
    Cascadia
    That looks good for an 8 ohm speaker.
    A 6v6 wants to see 4000 to 5000 ohms of impedance. If your ratio was 30 instead of 22, then 480 would be 900 or 1000. A 4 ohm speaker times 1000 is 4000. An 8 ohm speaker times 480 or 500 is 4000 ohms.
    Everything looks right on for an 8 ohm speaker, which may transfer more power than a four ohm speaker.
    ArcticWhite likes this.
  7. ArcticWhite
    Portland Oregon
    Thanks for the calculations above.
    Wondering what the resistance readings told us.?
  8. peteb
    Cascadia
    The resistances look good. Red-blue is the primary, black-green is the secondary.
    If you subtracted the resistance of your meter from 1.2 ohms, do you get less than one ohm? That is what I would expect.
    The 150 ohms on the primary looks good. I have two bf champs and the OT primary on those is 260-270 ohms. I believe that tweed champs and Princeton’s are going to have a DC resistance on the primary of around 150 ohms.
    This is speculation: when we first saw the resistances, before you did the impedance ratio measurement, I was thinking 150 ohms is lower than what I am familiar with, and that maybe that meant that a higher impedance speaker would be right. Then you did the impedance measurement and that indicates an 8 ohm speaker is what is needed to match what the tube wants to see. It all seems to work out and make sense with an 8 ohm speaker.
  9. peteb
    Cascadia
    Checking closer on the impedance ratio.
    AW measured an impedance ratio of 480. This multiplies the speaker impedance to the total impedance the power tube works into.
    4 ohms times 480 is 1,920 ohms
    8 ohms times 480 is 3,840 ohms.
    16 ohms times 480 is 7,680 ohms.
    The tungsol spec for the 6v6 tube calls out that the tube wants to work into a load of 5k rising to 8K as the plate voltage increases.
    It looks like an 8 ohm speaker will work, a 16 might be better, but since 8 ohm speakers are common and 16s are not, 8 is probably a good option.
  10. peteb
    Cascadia
  11. ArcticWhite
    Portland Oregon
    Wow, Pete. Thanks so much for this. I'm routinely amazed by how much generosity there is on this board. Thanks also to Tinfoil and others who helped me out.
