Transformer and tube placement - mostly Maggie amp
Discussion in 'Shock Brother's DIY Amps' started by jeff_e, May 23, 2020.
  1. jeff_e
    jeff_e TDPRI Member
    S.W. of Edmonton, AB
    So, I'm messing with headphones to figure out the best spot for the output. In line with the power transformer and about 4" away , the hum drops down and doesn't change a whole lot out to the far edge.
    I could put it way over, but where does that start to cause other issues..
    I'm thinking 6v6 kind of in line with where the output is and preamp tube a couple inches over. Does spreading things out a lot possibly cause noise with long leads?
    It's a 13.5" chassis. I guess I'm looking for some guidance and experiences so I don't get hung up for too long...
    Thanks
  2. jeff_e
    jeff_e TDPRI Member
    Sorry, here's the pic
  3. jsnwhite619
    jsnwhite619 Friend of Leo's
    Georgia
    I've built some dead quiet 5f2a Princetons with the transformers nearly touching. I guess it's only an issue if it is one? I wouldn't worry too much unless it's causing problems and you are sure it's the reason.
    Sent from my moto g(6) using Tapatalk
  4. BobSmith
    BobSmith Tele-Meister
    San Jose,CA
    I like the layout. Looks nice and clean!
    Off topic, but any reason you didn’t place a turret on the other side of the dropping resistor attached to a jumper wire? A turret would help keep it mechanically fixed, whereas the wire may let it move around too much and could cause the joint to fail. It doesn’t look like it’s too late to drill a hole and stake a turret.
  5. jeff_e
    jeff_e TDPRI Member
    Thanks, that's good to know. The copper shield on the PT seems to help a lot vs a Hammond I have.
    Thanks, yeah, I will do that... It does look funny the way it is.
    This has been sitting in a drawer for a long time, getting back to it.. I wish I had left some lead length for expansion. I do have another 470 cathode resistor handy , so I may swap that out. Nothing is soldered yet
