Trademark 60 opinions sought
Discussion in 'Amp Central Station' started by Bill Beck, Mar 28, 2003.
  1. Bill Beck
    Bill Beck Tele-Meister
    Indio, CA.
    Are they gig worthy? Is the clean side able to cut through a normal volume band with a med. hitting drummer?
  2. cowboy
    cowboy Tele-Meister
    West Gardiner, Maine
    I think it is a great little ss amp...
    hard to match the channels but you can usually tweak it for some decent sounds...takes a little playing around to find teh sound..I find that it is also sensitive to pedals..some sound great and some not so good...my FDII works great with my DR & SR but doesn't do it with the Tech21.
    I'll keep it for a backup and when I just need something light and easy to haul around. later.
    wilbur
  3. telest
    telest Tele-Meister
    Trademark 60
    I liked the "Fender" channel very much. The "Marshall" channel, not so much.
    Steve
  4. Bill Beck
    Indio, CA.
    Postscript
    I got and like it very much...still tweakin' with it, but it'll cut it just fine.
  5. trag-o-caster
    trag-o-caster R.I.P.
    Flushing, Michigan
    I played through one a few weeks back at an open jam. It was lined into the PA and sounded great out front AND on the bandstand. Seemed to cut through fine. I stayed on the Fender side.
    While trying it out at the music store I noticed that you really can't just switch from the Fender side to the Marshall side without serious re-tweaking. Initially I didn't like the Marshall side until I made some major tone adjustments. After that it was fine, although I still preferred the Fender side. Cheers! Trag.
