Top Load or Thru Body?
Discussion in 'Telecaster Discussion Forum' started by Stanford Guitar, Mar 5, 2021.
  1. telestratosonic
    telestratosonic Friend of Leo's Silver Supporter
    Alberta, Canada
    44BD08AC-6F6D-4ECE-8AA7-4799F52CE810.jpeg CDA8162D-A94D-4B36-A2BE-9EC021BC6C5B.jpeg DB4FB306-9053-4C5B-8856-A9C21AAD0FA0.jpeg BF251DB9-E183-4BB3-9C43-32805E5714F6.jpeg I like vintage bridges. What I like mostly is that I can hook my pinky finger on the underside of the bridge to 'keep my place' when picking.
    For years, I've been wanting to swap out the modern bridge for a vintage bridge on my 2008 Indonesian-made Squier Standard Telecaster.
    I bought it used back in August, 2012 for $170 CAD. I was working at an 8-week oil-refinery maintenance turnaround just outside Fort Saskatchewan, Alberta at the time. I was browsing Kijiji on my iPhone during my coffee break when I saw it for sale. I sent the seller a message and we agreed to meet at the nearby Fort Saskatchewan Walmart parking lot after work. I met the seller after work, had a look at the Telecaster, saw that it was in excellent condition and $170 changed hands.
    I've done some mods to this guitar:
    1) new Grover Mini Rotomatic tuning machines (great tuners but unnecessary as the stock tuners were fine) - $75 CAD back in 2013 or thereabouts;
    2) new Seymour Vintage Rhythm neck pickup - $55 CAD back in 2013 - I wouldn't buy it again;
    3) used USA Fender bridge pickup - $45 CAD - I bought on Kijiji and I'm happy with it.
    Back then, the Canadian dollar was equal to or worth a little more than the US dollar if memory serves.
    I drilled holes in the pickguard so I'm able to adjust the height of the Seymour Duncan neck pickup.
    The only thing I didn't change was the bridge. I bought the Wilkinson vintage bridge with compensated saddles on Kijiji for $30 on Kijiji some years ago. But the string-through-the-body holes didn't line up so I didn't install it. I checked StewMac and online for a suitable bridge but no luck there either. I even posted here about it.
    THEN, I saw this thread. I checked the bridge and lo and behold, it's a TOP LOAD as well as a THRU BODY.
    I had to drill 4 holes through the bridge to make it work but it works. The screws in the pics are red-colored so that you can see what I did. I'm happy with the TOP LOAD; I hear no discernible difference in the sound and I can hook my pinky finger on the underside of the bridge.
    At the rear and outside the bridge, where the strings load, I put the 3 screws from the modern bridge back in the holes. The vintage bridge doesn't cover the holes. If you look closely, you can see the 3 screw heads.
    I also have a Fender vintage bridge but it's not a Top Load. I would have had to drill holes at the back of the bridge to make it work. Not an insurmountable problem though.
    I also have a new Warmoth Telecaster neck I picked up on Kijiji in Edmonton last year for $200 CAD. The seller told me he paid $400 CAD for it. If the frets wear out, I can always swap out the neck.
    HALLELUJAH! ALL HAIL THE MIGHTY TELECASTER!! LOL!
    Here are some pics.
    hemmings likes this.
  2. hepular
    hepular Tele-Afflicted
    abilene, tx
    that would be relevant if said application were to produce ACOUSTIC vibrations. it MIGHT be relevant to the induction of electromagnetic signal through the pickups, but probably NOT in the manner that most participants in the tonewood debate think: as with passive tone devices, i guess that the interaction of various woods with string vibration will only dampen some aspect of the string vibration, or, some aspect of how the pickup is induced to respond to the string.
    unless we were all deriving our conclusions from the same guitars, with the same bridge/saddle/nut/pickups, our opinions will not derive from similar experiences: as many have noted, the difference in saddle quality (and correctness of adjustment) will produce a huge range of variance in string-through performance, and the same would be true for top-loaders.
    that said, i prefer string-through. because, in the immortal, and with her, argument ending words of my mom: "i like it."
  3. IrishB
    IrishB TDPRI Member
    Sweden
    I got an Esquire that came top loaded with 11s. Had it set up by a pro and asked him to switch to thru.
    Really not much of a difference if any. Maybe a little less slinky as someone mentioned.
    telestratosonic likes this.
  4. ndcaster
    ndcaster Doctor of Teleocity
    Indiana
    have both, too many variables to perceive any appreciable difference, let alone a difference that matters
    top load is more convenient and cheaper to build
    use the cheap Fender bridge plate and sand its bottom dead flat
    gmann and telestratosonic like this.
  5. palethorn
    palethorn TDPRI Member
    Sveti Stefan
  6. orangeblossom
    orangeblossom Friend of Leo's
    Renfrew county, Canada.
    I have both and there is no difference that I can tell. IMHO.
    Jim622, gmann and telestratosonic like this.
  7. Marblatx
    Marblatx Tele-Meister
    Austin
    My first Tele was an 83 and I didn't even know some were string through. I didn't find that out until around 30 years later.
    trev333 and telestratosonic like this.
  8. Froopenstein
    Froopenstein NEW MEMBER!
    Wiltshire Uk
    Toploaders : more slick sounding
    String through : more midrange tone & more emotive sounding
  9. ElJay370
    ElJay370 Tele-Afflicted
    Los Angeles, CA
    It's probably psychological, but I feel like the strings are more solidly mounted if they're going through the body, which in turn makes the guitar feel more substantial to me, which makes me play better....so it's a win all around, even if there's no science to back it up.
    And it also prevents me from having to look at those ugly-ass rainbow colored ball ends D'Addario insists on using.
  10. mjtrip001
    mjtrip001 TDPRI Member
    NJ, USA
    My tele bridge will allow for either thru or top load and I've used both. Thru has more sustain, top loaded is more raw and aggressive.
    Roscoe295 likes this.
  11. jimi00
    jimi00 TDPRI Member
    Paris, France
    I really didn’t like telecasters… until I played a Top Loader. The difference in slinky makes Through Loaders unbearable for my fingers.
    I don’t think the argument regarding sustain is justified. If it were, what to make of Les Pauls or even classical instruments?
    As for the sound, I’d be hard tried to tell the difference.
    northernguitar likes this.
  12. Jim622
    Jim622 Friend of Leo's Silver Supporter
    Philly
    Chant.......It just doesn’t matter, it just doesn’t matter., it just.........
    orangeblossom and gmann like this.
  13. pippoman
    pippoman Tele-Meister Silver Supporter
    Memphis
    String through, I guess, cause that’s how Leo designed it. I’ve played both and honestly don’t have a problem with either one. If you have a string through Tele and want to try a top loader just switch bridge plates. If you have a top loader and want to try a string through, tough titty.
  14. trev333
    Coolum Beach,Australia
    I'd been playing a nice '91 strat for a while. A mate brought over a tele that was for sale, a local studio was selling off some gear to buy digital desk stuff.
    It was an '83.... it felt as slick as snot compared to the strat, sounded wonderful...... I bought it on the spot... he left it with me before we worked out a deal with the studio guy.... I had previously got a super 210 off him cheap...
    later you find out things like it's a rare hard tail set up and a 12" rad neck.... try one..:)
    I never used to bend much with my strat playing.... with this tele I couldn't help but bend notes, it was so much easier.. and the guitar seemed to like doing it, too...:D
  15. bendecaster
    bendecaster Friend of Leo's
    maine
    Opinions vary. I've got both and prefer string-through, but I never really examined it that deeply. Just play and if you enjoy it, it's right IMO.
    Just play!
  16. Jay Jernigan
    Jay Jernigan Tele-Afflicted
    10-uh-C
    Definitely a subjective matter. I had a '92 MIM with the top load POS bridge; mediocre natural sustain, excellent harmonic feedback.
    I have a partscaster that is string-thru but suffers from the string holes being improperly drilled approximately a sixteenth of an inch too far back; it seems that the flatter break angle might shorten the sustain, but it could be other factors, also.
    Over wrapping a stop bar on a Les Paul allows you to set the bolts deeper; tune o matic bridge design only allows for a certain amount of break angle, which seems to be plenty.
  17. darkwaters
    darkwaters Friend of Leo's
    Newfoundland
    I'd prefer top load because I much prefer TOM bridges, but I can live with string thru. It's really not that big a deal.
  18. northernguitar
    northernguitar Friend of Leo's
    North of Toronto
    Cool! I don’t think I’ve seen a Tele with the TOM bridge. To me, it’s by far the easiest to set and intonate. However, I only have the one Tele and love it as is, with the classic three saddle bridge and string-thru.
    darkwaters likes this.
  19. darkwaters
    Newfoundland
    The only one I've seen is the Jim Adkins JA-90. It's very much a Fender Tele Thinline crossed with a Gibson LP Special hybrid, which I find attractive, but certainly wouldn't be to everyone's taste.
  20. northernguitar
    North of Toronto
    Neat. I had a Yamaha AES-620 for a time...string-thru and TOM. I thought it was a perfect design for a future custom guitar, some day....
