Top Hat Blues!
Discussion in 'Tele-Technical' started by 41144, Jan 29, 2018.
  1. 41144
    41144 Tele-Afflicted
    Brummagen
    This is going to sound ridiculous but ... is there some special technique for fitting a Top Hat switch cover?
    Last week a bit of over-enthusiastic switching during rehearsal saw my Top Hat fly off ...
    It's an AV64 Telecaster so checked on the Fender website and ordered part 099-4937-000. £13!
    Fortunately two in the pack so today ... on arrival ... went to fit one - it broke!
    Surely all you do is push it down/on?
    Or is there some special incantation needed first?
    btw - although not on this one, I've completely gutted guitars before now and never been stumped by putting the switch cover on at the end of a project.
  2. brookdalebill
    Austin, Tx
    I’d get a switch tip with a set screw.
    SnidelyWhiplash and troy2003 like this.
  3. Smiff
    Smiff Tele-Holic
    Bit of chewing gum, play doh or something in the top hat to ‘stick’ it on?
    Or superglue for a more extreme fix?
  4. 41144
    Brummagen
    Brookdalebill .... If only I could :)
    Smiff ... Think that's how it left the factory :lol:
  5. Ira7
    Ira7 Doctor of Teleocity
    Coral Springs, FL
    I never saw that.
  6. troy2003
    troy2003 Friend of Leo's
    Rutters makes a cool one that matches the existing knobs. It’s on my “hope someone buys it for me” list.
    brookdalebill likes this.
  7. brookdalebill
    Austin, Tx
    Armadillo here in Austin, too.
    It's a great idea, the set screw knob.
    I circumvented my hassle with the dern things by installing a Gibson type switch in a Gibson-like place on my guitar.
    That's probably way too radical for you Tele purists.
    I greatly prefer it.
    Fiesta Red and troy2003 like this.
  8. 41144
    Brummagen
    I am talking switch tips here fellas not control knobs ... getting me even more confused now :eek:
    Checked Armadillo and Rutters ... no switch tips, unless that's a secret/special page for USA only ;)
  9. Seasicksailor
    Seasicksailor Friend of Leo's
    Keynsham UK
    A bit of sellotape around the metal bit does the trick for me.
  10. Ira7
    Coral Springs, FL
    I just wrap some electrical tape around the the switch shaft to make a tighter fit when pushing the tip on, for those that don't go on tight.
    Some switches have different profiles, as do the tip "holes," and it's a PITA at times and not one size fits all.
    But tips are cheap enough to lose one occasionally.
    Seasicksailor likes this.
  11. Ira7
    Coral Springs, FL
    You beat me by ten seconds.
  12. WireLine
    WireLine Tele-Afflicted
    Midland TX
    I’ve always used a half width of plumbers pipe tape...never lost one.
  13. Seasicksailor
    Keynsham UK
    SUCK IT!!!!
    [Does 20sec victory dance around the room while screaming rhythmically 'Ira7 is a LOSER!']
    LutherBurger, Ira7 and Anode100 like this.
  14. troy2003
    Brummagen
    Is it me ... must be ...
    The problem isn't getting the switch tip to stay on ... its getting it on in the first place.
    I've got other (non-Fender) tips that will fit ... what I'm trying to establish is why, according to the Fender parts layout diag. for the AV64 ... the correct Fender switch tip replacement part will not push on to the switch.
    End of the world - No ... annoying Yes!
    So, has anyone out there had cause to replace an AV64 switch tip?
    Did you use the Fender replacement part ... if Yes, did it go on easily ... if not can you explain how you managed to get it on
    OR
    Did you just buy a cheap knock offs from sleazebay or similar and hope for the best ... Cheers.
    Strummn1 likes this.
  16. Anode100
    Anode100 Friend of Leo's
    Behind my beard.
    You may well have a 'metric' switch.
    I recently put a top hat tip on my partscaster - and the metric one did not fit - it was far too tight.
    I found a slightly more expensive imperial one, and it fits like a glove.
  17. 41144
    Brummagen
    troy2003 likes this.
  18. 41144
    Brummagen
    Anode100 ... metric/imperial can be a bind but this is "as was" out of the shop.
    So unless Fender messed up with the actual switch part .... a Fender Replacement switch tip part should work ... :mad: grrr
  19. Ira7
    Coral Springs, FL
    I would be frightened of a guitarist using that KNOB as a SWITCH!
    41144 likes this.
  20. Ira7
    Coral Springs, FL
    Now THAT'S funny!!!
