mountainhick
First will probably be conversion from an old organ amp. Chassis will not require much if any drilling, but I have access to a drill press.
Step bit(s)
I can understand how a Variac could help as I get farther down the line and start designing on my own, same as an oscilloscope, but why do you suggest those as requisite tools from the beginning?
Additionally, I have a load resister (8ohm headphones) and signal generator (guitar) already. Is there any reason not to use these and to get something specialized instead?
If you aren’t going to make any errors in your build, then you won’t need a scope.
If you are going to apply full power to the build, that has no errors, then you won’t need a variac.
What is the wattage of your headphones? (asking for a friend)
Test the amp using the guitar as a signal generator and get back to me.
What I hear you saying is that I’ll need these things because I’ll make mistakes but that doesn’t tell me how I need to be prepared to use them. If you’re not up to answering that question that’s cool.
I’m putting myself out there asking honestly for advice and I feel like you’ve belittled me for asking.
Seems like you have and know everything you need - best of luck
Personally, I find a signal generator very valuable. I have always used an app for this, with a 1/4 inch to 1/8 inch adapter so I can plug it from my phone's headphone jack into the input jack of the amp I'm working on.I can understand how a Variac could help as I get farther down the line and start designing on my own, same as an oscilloscope, but why do you suggest those as requisite tools from the beginning?
Thank you for your detailed explanation. That was really helpful!Personally, I find a signal generator very valuable. I have always used an app for this, with a 1/4 inch to 1/8 inch adapter so I can plug it from my phone's headphone jack into the input jack of the amp I'm working on.
Here is the reason for using a signal generator. A guitar is a complex audio signal with decaying amplitude that will confuse a multimeter's AC voltage reading. Most meters aren't going to give you an accurate AC measurement while you strum your guitar and an accurate reading is still going to be all over the place. You can't strum consistently AND it ties up your hands.
If you want to chase a signal through your amp, having a nice steady 50 to 100 mv sine wave adjustable for various frequencies is extremely helpful. Using a signal generator in conjunction with an AC voltage reading will tell you if your gain stages are working correctly. You can see how that bright switch changes your response at 5K. You can see how that icepick cap in your feedback loop filters out highs at our speaker. You can see how much your tone stack attenuates the signal at different frequencies by measuring before and after. I have used a signal generator app for commissioning the half dozen projects that I've completed. The downfall of a phone is the voltage does not seem to be constant across frequencies and varies with charge. I would like to have a better resource so I'm watchin eBay for an old audio function generator.
Where a scope comes in handy is looking at waveforms, distortion, phase inversion, phase inverter balance, etc. Are you cold clipping? Hot clipping? If you have two channels you can find out if your PI output is balanced. I don't own one. I sold mine years ago before I started this hobby and could shoot myself now. I have two very good graphing meters that are identical, so I can get by... sort of.
At any rate, you don't need a scope. The signal generator is practically free, you just need a PC or phone and a cable.
Here is the one I use. This guy has a windows app and a phone app.
I have a lot of this stuff from my great grandfather's toolkit -- he was a pipe fitter. I cannot tell you how much I swear by his measuring tools which are undoubtedly 100+ years old and still use them in my woodworking projects. Since I have a basic MM I'll probably get a second one that's nicer along with a couple of the other hand tools you mention. Thank you for the specific recommendations!Nice wire stripper like Hanlong HT 5023R (my favorite)
Helping hand fixture
Needle nose pliers
Flush cutter
Hemostat with holding catch
Step drill bit
Dentist pick for undoing wires when soldering
Maybe a sheet metal nibbler
Maybe a couple 50w 8 ohm dummy load resistors
A frame (can be homemade) for supporting the chassis at a comfortable angle.
Automatic (spring loaded) center punch for piloting holes.
Chassis punch for tube base holes
A second multimeter
set of small machine taps
machinist tri square
Bias tap and piston-type solder sucker added to the list. Stapler I have, but I'm still reading up on wood cabinets (esp solid wood vs composite/ply) and may want to do something nicer. I have some old wood cabinets with solid veneer that look amazing and could make for an excellent speaker / amp cab as long as they're not unduly influencing the tone. Being from Portland, it would be fun to find some PDX Carpet tolex for a smaller project. One of my projects is converting an old organ into an amp/cab setup. Would likely use the wood from that to build.-Flux. No Ko Rode. Helps immensely for soldering to chassis or pots etc.
-Solder sucker (The piston type not the rubber bulb type)
-A good set of Dikes.
-Good needle nose pliers, short and longer. Make sure the tips align well when closed.
-A good stapler for tolexing etc. The T10 works fine with 5/16" staple length.
-You will want a bias tap (inserts into a tube socket) for ease of biasing. You can do without it though. They are cheap.
-Your multi meter needs some long leads and alligator ends to attach. Some cheapies have very short leads.
-Your multi meter needs to read Milliamps for biasing. Many dont.
I have been wanting some nut drivers with deeper wells. Maybe now is the time. I'm horribly nearsighted so I might forego the magnifying visor or just use my readers for when I have my contacts in. That said, I believe my dad may have a pair he uses for lapidary work.Deep well nut driver sets are nice for installing pots.
Flush cut wire cutters.
Magnifying visor is a game changer for soldering in tight confines.
A resistor, wire, ink pen, and alligator clip to make your own capacitor drain tool.
A small hobby vise for the times when you need 3 hands.
I just find it simplifies soldering. Allows you to not use too much heat on pots etc. I've used it for 40 years.Since there's been a lot of discussion so far, I'm going to sum up as much as I can so far.
All of the electronic solder I've used is rosin-core and I was advised *not* to use flux. Why do you recommend it?
I've also seen a lot of recommendations for the following:
- Light bulb limiter and/or Variac (thank you to everyone for your explanations of usage -- I can now understand why these are both helpful and why the Variac might be a better option on later builds. The limiter is going in my project list right away. and if I want something more granular, I can upgrade to a Variac.
- 8Ω 50W load -- thinking this might be a fun project build but they're so cheap I might just buy it.
- Oscilloscope -- sounds like this is for some pretty granular testing. Going on my "maybe" list.
Flux is awesome. You were maybe advised not to use a corrosive flux, as is used in plumbing and other commercial applications? Or maybe that was the intent of the advisory. Otherwise I can't think of why a warning about flux would be issued, like you said it's already in the solder we use...All of the electronic solder I've used is rosin-core and I was advised *not* to use flux. Why do you recommend it?
