Tone problem
Discussion in 'Just Pickups' started by Cowboytele, Oct 21, 2019.
  1. Cowboytele
    Cowboytele TDPRI Member
    Tennessee
    I had in the past put a 4way switch on my tele and just recently I had it replaced back with a 3way. Ever since then my tone has become dark and the volume a little low. I opened it up to see a ground wire had been added to the metal part of the switch and grounded to the volume pot. Could that be the culprit?
  2. LKB3rd
    LKB3rd Friend of Leo's
    CT
    I would go back to whoever did the work and ask them, if it wasn't you.
    Changing only the switch, I wouldn't expect the sound to change, other than due your switching options. The bridge pickup by itself should sound just like it did before, same with neck pickup alone..
    brookdalebill likes this.
  3. brookdalebill
    Austin, Tx
    Howdy and welcome.
    I too recommend you take it back to who ever did the
    work, and gently register your dissatisfaction.
  4. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Could be something simple like a ground wire touching a hot lead after repacking the control cavity.
    POS Guitars likes this.
  5. POS Guitars
    POS Guitars Tele-Meister
    Los Angeles
    I agree. If there is just a tiny short to the ground, it can sound muddy and low, and still work.
  6. Cowboytele
    Tennessee
  7. Cowboytele
    Tennessee
    Well, after looking a little closer I found that the lead from the bridge pickup going to the volume pot was barely hanging on and actually broke off when I touched it! So I think I found my problem!
    But thanks for everyone’s advice. I’m glad to be in this group.
    JustABluesGuy and POS Guitars like this.
