Tone of Fixed vs. Cathode Bias
Discussion in 'Amp Central Station' started by bobbyk, Feb 20, 2012.
  1. bobbyk
    bobbyk TDPRI Member
    Connecticut
    Okay, take the same 2 x 6L6 amp. Is there a noticeable difference in the tone if the amp had fixed bias as opposed to cathode bias? Noticeable enough that doing a fixed/cathode mod would be worth the effort?
    Thanks in advance.
  2. celeste
    celeste Friend of Leo's
    Maryland
    There is still a lot of room for other parts of the circuit to have large effects on the outcome. The presence and size of the cathode bypass cap has a major effect on the feel or a cathode biased output stage,
  3. printer2
    Put a 1000uF cap across the cathode resistor to get an idea on the difference. Tried it on one amp I have and while I can hear a subtle difference when I switch it in it does not change the sound much. As celeste says, other parts may determine how much of an effect it has. I have a feeling it would not make much difference with my combination. Not going by experience but I have the feeling it would be more noticeable the higher in power the amp.
  4. celeste
    Maryland
    Don't forget, Vak changes switching between the two, unless you turn the B+ on the fixed configuration by an amount equal to the bias voltage of the cathode biased configuration.
