Tone loss issue. Input appreciated!
Discussion in 'The Stomp Box' started by 6BQ5, Apr 9, 2015.
  1. 6BQ5
    6BQ5 Tele-Afflicted
    Pittsburgh, PA
    So I'm having an issue with tone loss. To the degree that I have been considering just paring down my pedal chain to the bare essentials (five pedals). More than those five and the tone loss becomes unacceptable to me. An additional buffer didn't help, and neither did a loop switcher. So I had a thought just now. My amp has two inputs. What if I were to run a chain of pedals into one input, and another into the second input, and then switch back and forth between them with an a/b/y box. Sure I wouldn't get to use some pedals with some others, but that would be true anyway if I have to leave them out of the chain altogether. Has anyone tried this? Would it work? Is there any consequences of using both inputs on an amp simultaneously, even if only one is getting a signal at any given time?
  2. watercaster
    watercaster Tele-Meister
    NY
    I'm sure that would work fine. I have amps with as many as four inputs and back in the day when no one had money, all the guitars and mics too were plugged into the same amp all at the same time. Didn't sound the greatest mix but it worked.
  3. waparker4
    Philadelphia, PA
    If you haven't gone through the board pedal by pedal and patch cable by patch cable, now would be the time. What pedals are they, which ones cause the tone loss? Is it two pedals in a certain order that is causing it?
    I think your idea should work. It is fun to play with a lead channel and a rhythm channel.
  4. DaveKS
    DaveKS Friend of Leo's
    KS
    You got a loop switcher, as posted above set down, put patch cables as a jumper in loop one at time, weed out any bad ones. Now you've got 2 good patch cables, now put each pedal one at time in loop and find out which ones are the culprits. If you have a looper it very easy to find the problem children in the chain, those are the ones that go in looper or get replaced/removed.
  5. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
    I can relate to the problem. I ditched a compressor the other day when I finally figured out which pedal was causing my tone loss...not to mention adding a lot of hiss to the chain. As an added bonus, I've discovered I'm not really a compressor sort of guy. (at least with my Vox AC-15)
  6. Doctorx33
    Doctorx33 Tele-Afflicted
    Atlanta
    5 pedals is not bare essentials.
  7. waparker4
    Philadelphia, PA
    Good point!! We all have to play guitar the same way after all, right? It's like a law or something?
  8. luckett
    luckett Banned
    If you're getting still getting tone suck when all the pedals are bypassed with the looper like you said, the patch cables are not the problem. It might be the cable between the pedals and the amp. Try plugging straight into the amp with that cable and see what happens.
  9. telemnemonics
    How the loop switcher is used makes a difference.
    A single loop can isolate a string of pedals or just one, and you can use several loops to allow an unlimited number of pedals connected but as few as zero in the signal chain.
    If all pedals are switched out of the loop and there is still tone loss it must be cables.
  10. semi-hollowbody
    semi-hollowbody TDPRI Member
    Metro Detroit, MI
    this
    you already cut down the number of pedals in your chain when u added the switcher (assuming its a quality switcher) and it didn't work...so the number of pedals aint the problem
    were ALL your pedals in the switcher when u tried this?? If not, then one or more of the pedals NOT in the switcher is not playing nice
    run guitar-switcher-amp...with no pedals in the switcher...see if you notice tone loss
    tone loss is usually high end loss...maybe adding a pedal lol...an eq pedal is the answer...cable runs true bypass and no buffer issues usually result in high end loss...aka...tone suck
    NEVER EVER EVER start with removing pedals...never ever try and shrink your pedal board unless there is no other way...downsizing is evil and immoral...;)
  11. 6BQ5
    6BQ5 Tele-Afflicted
    Pittsburgh, PA
    I used the same cables both with and without the switcher. Is it possible that a 4 loop switcher is acting the same as having 4 true bypass pedals in a row in terms of causing high end loss?
    I'll try the looper only setup and report back. Thanks everyone.
  12. Doctorx33
    Atlanta
    Thank you for that useless and smart assed remark.
    I was stating an opinion, one of many valid ones in this thread.
  13. 6BQ5
    6BQ5 Tele-Afflicted
    Pittsburgh, PA
    To be fair, your opinion offering wasn't exactly constructive, nor was it addressing the question originally posed.
    It's not just you of course, there seems to be an inevitability that whenever someone asks pedal related questions, someone will respond with some kind of generally "less is more" sentiment. It's frustrating.
  14. Hellmark
    Hellmark Tele-Holic
    O'Fallon, Mo
    When troubleshooting, 5 pedals isn't bare essentials. That's the thing, we're NOT talking about normal playing. We're talking about trying to diagnosing a problem. The more things you have in the mix from the start, the more difficult it is to diagnose the problem. We don't know if the tone issue is with the guitar, the amp, one of the 5 pedals, or the 7 cables in between everything.
    Start with just the guitar and amp. Do you have tone loss? If so, try another cable. Still have tone loss? Test if other guitars also have the tone loss. If you don't have tone loss yet, then plug in one of the pedals and test. Keep adding in until you do have tone loss. The last thing added is the culprit.
    Once the issue is solved, then you can go back to your normal gear.
  15. 6BQ5
    6BQ5 Tele-Afflicted
    Pittsburgh, PA
    Special thanks to you two gentlemen who answered the question that I asked. Much appreciated.
  16. telemnemonics
    Maybe yes, but IDK which 4 TBP pedals you're comparing to which 4 loop switcher, and I'm not sure if all multi loop switchers are the same.
    It would be worth going back to Waparkers question asking specifically what pedals are giving you trouble in what arrangement.
    It is possible to use a loop switcher the same way you would use the two channels of your amp, if you can arrange several FX in a given loop, and use fewer loops.
    I guess it's probable that a 4 loop switcher would be exactly the same as 4 TBP pedals, except the patch cords would be replaced with whatever high or low quality internal wiring the switcher uses.
    But the option of running 12-16 pedals in the 4 loops puts the switcher way ahead of running 12-16 pedals at once.
    I don't use many pedals at once, but like the loop option to create banks of pedals I want to run together.
  17. waparker4
    Philadelphia, PA
    Yes, which is to say, not very much high end loss, IME.
    Then again, all my boards have something buffered in 'em. You might want to experiment with a buffered pedal before or after the 4-channel bypass looper
  18. 6BQ5
    6BQ5 Tele-Afflicted
    Pittsburgh, PA
    Yeah, I have a buffered pedal in the chain already, a j. Rockett archer. I also tried using a stand alone buffer at various points in the chain.
  19. RyanJH
    RyanJH Tele-Meister
    What exactly are the pedals in your chain? Some pedals just don't get along with others, some have terrible bypassing methods, low input impedances, high output impedances or any combination thereof...
    -Ryan
  20. 6BQ5
    6BQ5 Tele-Afflicted
    Pittsburgh, PA
    Polytune>archer>dr. J green crystal>carbon copy>ditto looper. That all works well together. When I tried to add the voodoo lab tremolo between the crystal and the carbon copy the problem began. I also tried adding a red witch fuZz God just before the archer (buffered) which also didn't work so well. As long as I stick to the Polytune>archer>dr. J green crystal>carbon copy>ditto looper, all is well.
