Tone control for P90s
Discussion in 'Twanger Central' started by flester, Nov 27, 2018.
  1. flester
    flester TDPRI Member
    Ireland
    I have a self build guitar with two P90 pickups, with Neck, Bridge or Both switching. I tried a (very!) cheap tele style loom but the tone pot has little or no effect. Whats a good place to start with pot/capacitor values? I mainly just want to be able to darken the tone on the Bridge-only setting even if it does nothing for the other settings.
  2. Crafty Fox
    Crafty Fox Tele-Afflicted
    Perth Australia
    I used 500K CTS pots and .022 capacitor on my recent 2 x P90 Thinline. I'm VERY happy with that guitar. I love the sound.
  3. maxvintage
    maxvintage Friend of Leo's
    Arlington, VA
    I sometimes use 500K pots with p90s, but almost always a .047 cap. Do you know if your tone pot is an audio taper pot or a logarithmic pot?
  4. flester
    Ireland
    Thanks. I will try that setup externally before hard wiring in. Unfortunately my design means its a bit fiddly to open up the control cavity so I try to do it as little as possible.
  5. flester
    Ireland
    Not sure if my existing one is Lin or Log but its a cheap one anyway. Will try various options on proto board. In a way I wish I had left out the tone pot as most amps and pedals have them anyway.
  6. DrBGood
    DrBGood Tele-Meister
    Sutton QC, CANADA
    I'm a bit confused here. If that seem like a viable solution to you, why then don't you leave the tone maxed on your guitar and play with the amp and pedals EQ ?
    Another avenue would be to change magnets on your P90. I had a too bright p90 and went from A5 to rought cast A2 and it got me where I wanted. $4.79 for a pair of magnets.
  7. BCblues55
    BCblues55 TDPRI Member Gold Supporter
    Charlottesville, Virginia
    I use 250k audio taper and have been very pleased with the results. Much more even reduction of high end as you go from 10 to 1. YMMV
    For me, cap value depends on how bright a guitar is. If it’s a bright guitar like a Tele, I’ll go with a .047. If it’s a darker guitar like a Les Paul, I’ll go with a .022. Most of the time I leave the tone control at 6 or 7 and adjust from there. Again, YMMV.
  8. flester
    Ireland
    Well, once I start exploring one angle ( e.g. how to fix my tone pot), I start to think of others( e.g. do I need a tone pot?)
    Sorry I do change my mind a lot (or do I?).
    DrBGood likes this.
