To effects loop, or not to effects loop . . .
Discussion in 'Glowing Bottle Tube Amp Forum' started by TeleBrew, Apr 4, 2018.
  1. TeleBrew
    TeleBrew Doctor of Teleocity Ad Free Member
    Evergreen, Colorado
    So who has an effects loop on their amp? Do you use it? Why?
    Do you not use it? Why?
    I might have an issue with the loop on my Hot Rod Deville 2x12. The other night at band practice everything was fine for the first couple of hours, and then the volume pretty much cut in half. The tone was identical, no weird noises or popping, just a big drop. I did some research and of course it could be one of half a dozen things, and I'll figure that out, but I'm just curious how necessary the effects loop is, or if most people just go, "meh," and skip it.
  2. stratoman1
    stratoman1 Friend of Leo's
    Virginia Beach, Va
    They're great for your time based and modulation effects
  3. jaybones
    jaybones Friend of Leo's
    Kelleys Island, Ohio
    Bugera V5 Infinium has no FX loop.
    Any stomp boxes I put right into it.
  4. TeleBrew
    Evergreen, Colorado
    I have heard that, as well. What's your experience been like? Have you noticed a real difference between putting them in the loop versus leaving them out? Thanks.
  5. Televised
    Televised Friend of Leo's
    Portland, OR
    I run my Reverb, Chorus, and Delay through the Effects loop and it is less muddy on all fronts. The whole amp is also not as noisy with less hum etc.
    stratoman1 and TeleBrew like this.
  6. stratoman1
    Virginia Beach, Va
    It helps keep your sound from getting all mushy
    TeleBrew likes this.
  7. DrGnosis
    DrGnosis TDPRI Member
    Reading, MA
    I rarely use effects other than overdrive here and there; however, and perhaps someone could correct me, but I might be concerned about a negative influence on sound quality from a long cable run if you were to want some of the pedals from your pedal board through the effects loop -- depending on how far away from your amp you typically are.
  8. Mike_LA
    Mike_LA Tele-Afflicted
    Just past 11 on the Dial
    I use a looper pedal and find an fx loop indispensible.
    W.L.Weller likes this.
  9. Frodebro
    Seattle
    Most loops are line level, so longer cable runs are much less of an issue than with instrument level signals.
    DrGnosis likes this.
  10. TeleBrew
    Evergreen, Colorado
    I ended up dropping my amp off at a tech in Denver (Colorado Forumites: Vacuum Tube Supplies is an amazing shop. And the nicest people you'll ever meet. 7th & Marisposa). I do thing there's something amiss with the effects loop.
    Anyway, is it normal for an amp to be a little noisier with effects plugged into the effects loop? My other amp, a Blues Deluxe Reissue, hums louder when my board is in the loop than it does with no effects plugged in. Thoughts?
  11. W.L.Weller
    W.L.Weller Tele-Holic
    Queens
    I have a Fender Power Chorus that’s got mono and stereo fx loops. Lately I’ve been putting my Digitech stereo loop pedal in the amp’s stereo loop. The level control on the pedal has a much more useable range in the amp’s loop
    The delay on my board is almost always set to self-oscillate, plus it’s not a stereo delay, so it’s better straight in. If I get a stereo in/out delay like the Alter Ego at some future date, I’ll have to re-evaluate.
