Tips to Clean Up a Field Recording?
Discussion in 'Recording In Progress' started by The_Doctor [EV], Sep 2, 2019.
  1. The_Doctor [EV]
    The_Doctor [EV] Tele-Meister
    Virginia
    So I just got back from a party over the weekend at which I recorded a friend's band (three piece: acoustic guitar, electric guitar, bass) with my recently acquired Zoom H2N. Overall, I'm pretty satisfied with it. We had a good mix, good ambiance from the crowd and the nature sounds around us, I'm very impressed with the recorder so far.
    However, they're looking to put it up on their Bandcamp, and I was wondering if I could get any tips on how to EQ it to boost the vocals a bit? I have a *very* basic sort of understanding of home recording, but I've never tried to sweeten a single-mic field recording like this. Any way to up the vocals without messing with the overall sound too much?
    Any help is appreciated, and I'm willing to post an example if it helps.
  2. KG7IL
    KG7IL TDPRI Member
    Eatonville, WA edge of cowtown
  3. beyer160
    beyer160 Friend of Leo's
    On Location
    Don't think in terms of boosting the vocal, think about eliminating the frequencies that are burying it- probably low midrange stuff in the 300-600 hz area. The rule of thumb for EQ is "always cut, never boost." There are exceptions of course, but you're much better off cutting offending frequencies.
    A super spiffy tool for this is a multiband compressor, which will compress frequency ranges that you define. In other words, instead of just chopping out the 300-600 range you can compress it so that there's still some life in that area, but the compressor keeps it from overpowering the vocal. Reaper has two you can use for this purpose, called ReaXComp and ReaFIR.
    joealso, Mouth, 24 track and 2 others like this.
  4. 24 track
    24 track Doctor of Teleocity Ad Free Member
    kamloops bc
    exactly what i was going to sugest
    beyer160 likes this.
  5. beyer160
    On Location
    Great minds think alike... apparently ours do, too!
    24 track likes this.
  6. 24 track
    kamloops bc
    I think this comes from experiences, in the studio and live, LOL
  7. Larry F
    Iowa City, IA
    Hey, I was going to suggest this, too.
  8. studio
    studio Poster Extraordinaire
    California
    Yes, can you please post the recording? Thanks.
    That'll give us some idea for your project.
  9. chulaivet1966
    chulaivet1966 Tele-Afflicted
    The Heartland.....Kansas
    Ha....you stole my thunder! :)
    OP....begin with the above is my suggestion.
    A good day to all....
  10. woodman
    woodman Grand Wazoo @ The Woodshed Gold Supporter
    Pisgah Forest, NC
    I would see what I could do with surgical EQ before firing up the MBC. Like Beyer said, attack the low mids first (if you're not familiar with the "EQ sweep" technique, google it). Then high-pass (low cut) the subsonic frequencies — without a kick drum, you're not gonna have much musical content below about 50 Hz; most everything down there will be mud. Between those two EQ moves, you'll defeat a whole lot of the room boom and be able to hear what else needs to be done. Next sweep for midrange resonances, then search out hissy noise in the highs with an eye toward maybe rolling off the top end — with no cymbals to worry about, there's not much musical way up there either (above 10k). ... If your EQ doesn't have enough bands, it's OK to use two instances of it on your track. EQ always opens up some phase issues, but they're trivial compared with the background din of an open-mike live recording. Good luck!
  11. LKB3rd
    LKB3rd Friend of Leo's
    CT
    This would be a minor thing, and may not work for your particular recording, but I got a tip somewhere for a particular EQ, with a bell shaped band at 2.8khz. You boost a half db at 2.8 and it tends to bring vocals out slightly.
