tips on cutting nut?
Discussion in 'Tele-Technical' started by doghouseman, Oct 26, 2020.
  1. doghouseman
    doghouseman Tele-Meister
    in your head man....
    just got a neck from warmoth and the slots in the nut are too narrow for fat strings. So I guess I need to open them up a little bit?
    I would like to put 12s on the bottom but right now it only takes 10s.
    Any tips on nut cutting?
  2. 2manyteles
    2manyteles TDPRI Member Silver Supporter
    Ottawa, Canada
    Don't gouge the headstock. Go slow. Use good files.
    DavidP and doghouseman like this.
  3. danlad
    danlad Tele-Meister
    Here and there
    If it is width and not depth that's the problem then you can try just a strip of sandpaper through the slot. Can't remember what grit I used, it was just a scrap I had, but went gently and it worked well.
    doghouseman likes this.
  4. swervinbob
    swervinbob Tele-Holic
    Hopefully not your own! Find a good doctor!
    Wait. We might be talking about different things.
  5. Freeman Keller
    I like to use a file that is 2 to 4 thousands wider than the string. You can rock it slightly to widen the slot but be careful, it is possible to break the nut. Approach the final depth slowly - you can always take a bit more off, its hard to put it back on. Roll the exit of the slot towards the tuner.
    I measure both first fret clearance and back fret clearance (fret at 3, measure the gap at 1). Do the frets first, of course and make sure the relief is where you want it.
  6. doghouseman
    Got a file coming from Stew Mac. I would assume they have some of the best files.
  7. Freeman Keller
  8. Paulie_Boy
    Paulie_Boy Tele-Holic Silver Supporter
    Varies. (Witness Protection)
    Cradle some sandpaper around a 9 or 10 gauge string then sand the slot as needed, frequently laying in the 12 until desired. Mind the depth.
  9. 1293
    1293 Poster Extraordinaire
  10. TimTam
    TimTam Tele-Holic
    Melbourne
  11. teleplayr
    teleplayr Tele-Afflicted
    Nicoma Park, Oklahoma
    Plenty of videos online to answer your questions.
    Here's one to start with....
    SecretSquirrel likes this.
