Tips on "clamshell" chambered body construction?
blackbelt308
Columbus, Ohio
And the first one is finished! Turned out pretty good too... Compare to the boat anchor rosewood Jazzmaster in my original post! This one weighed in at exactly 8 pounds.
The process was relatively straightforward... After re-sawing (thanks Brian!), I glued up each set of bookmatched halves, like this:
Added a thin slice of curly maple to one of the sides, then used my templates to hog out the chambers:
Finished with the laminate trim router:
Glued the chambered & indexed (with dowel pegs) halves together, then cut and routed the body shape and cavities:
Finished the walnut by sanding through 2500 followed by several applications of linseed oil and beeswax. Here's a few more pics... Once again I went with the Curtis Novak JM-WR pickups. Each pickup has its own volume control with push-pulls to split the coils. Body side output jack with recessed electrosocket, single-ply celluloid tort guard, Sounds great!
Couple more in the works! Thanks again to those of you who shared ideas and tips in response to my initial post!
Ciao!
Rick
blackbelt308
Columbus, Ohio
Second chambered Jazzmaster is finished! This one's the "negative" of the walnut Jazzblaster above... Blonde wood with a brunette sandwich layer! Chambered Monterey pine with a center layer of Ohio black walnut. The finished guitar weighed in at 6 lbs 8 ounces!
"Stratomaster" configuration with Bootstrap '54 Vintage Sparkle pickups, master volume, master tone and blend controls. Staytrem bridge and arm. Sounds amazing! :)
