Tiny amp big sound
Discussion in 'Shock Brother's DIY Amps' started by tubeToaster, Sep 20, 2020.
  1. tubeToaster
    tubeToaster TDPRI Member
    Brentwood,Tn.
    I built a 5F2A into a 5”x7” chassis. The power transformer is a Weber WRVBPT made for a stand alone reverb. With ss rectification it gives me 343 volts on the 6V6 plate. The output transformer is from a Epiphone Valve Junior.
  2. awasson
    awasson Poster Extraordinaire Gold Supporter
    Vancouver
    Nicely done! That’s a really cool little amp.
    Something like this might scratch that itch I have for building a Champ.
    Does that 220k resistor on the 10uF electrolytic get hot? I tend to get OCD when resistors are so close to caps.
    goonie likes this.
  3. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
  4. FenderLover
    Minnesota
    You didn't use the term, but it's a size that puts the 'micro' into a small build. Cool!
    Does the 470K on the 6V6 grid make it to ground? I don't see a connection there.
    SnidelyWhiplash likes this.
  5. tubeToaster
    Brentwood,Tn.
    There is a small gap between them
    awasson likes this.
  6. tubeToaster
    Brentwood,Tn.
    Thanks. It is grounded. The ground runs under the board. I changed the 470k to 220k. I felt like it was driving the 6V6 to hard
  7. awasson
    Vancouver
    I’m putting together a shopping list now.
  8. tubeToaster
    Brentwood,Tn.
    The Weber WRVBPT is only $26 and is 100mA. Works great for a champ build as long as you don’t mind having a diode rectifier
    FenderLover and awasson like this.
  9. Peegoo
    Peegoo Friend of Leo's
    Wyoming panhandle
    That is really beautiful work, tubeToaster.
    The ep-pit-tome of boo-teek!
    dlaroe and tubeToaster like this.
  10. awasson
    Vancouver
    I’m happy with diode rectification. I’m looking at their W022905M output transformer. I’ll need a chassis and I’ve got everything else on hand.
  11. telemnemonics
    Pretty cute!
    Is it quiet?
    Champs are generally lounging in an over sized chassis, they really oughta be more respectful of real estate!
    Look in an old Boogie at the over crowding, why do the little 5 watters get such luxy accommodations?
  12. tah1962
    tah1962 Friend of Leo's
    Heart of Illinois
    Nicely done. Very tidy work! Enjoy.
    tubeToaster likes this.
  13. tubeToaster
    Brentwood,Tn.
    Tha
    Thanks. I’m trying to figure out some kind of cabinet or cover that won’t add to much to the size.
  14. SnidelyWhiplash
    SnidelyWhiplash Friend of Leo's
    Hoggtown, KY.
    I'm sorry, but wouldn't the 220k make the bias hotter??? :confused:
  15. tubeToaster
    Brentwood,Tn.
    It is very quite. And I forgot to add an artificial center tap to the filament wires. But no hum. Maybe the resistor and diode circuit for the LED that is hooked to the filament wires has something to do with it. I don’t know
  16. tubeToaster
    Brentwood,Tn.
    I’m referring to the grid leak resistor. There is 3 470K resistors in that photo. I think the grid leak resistor is the one FenderLover was referring to.
  17. 39martind18
    39martind18 Tele-Afflicted
    Spring TX
    Wooden cigar box?
  18. James Knox
    James Knox Tele-Holic Silver Supporter
    Phoenix
    Really cool!
    I’ve not seen that kind of turret board before. Where do you get that from?
  19. Peegoo
    Wyoming panhandle
    If I had your username, I'd probably locate one of these and use the shell for a housing. It's already got top vents.
  20. tubeToaster
    Brentwood,Tn.
    Antique Electronic Supply
    tubesandmore.com
    James Knox likes this.
