Timmy bypass problem
Discussion in 'The Stomp Box' started by tweedtone, May 20, 2018.
  1. tweedtone
    tweedtone Tele-Afflicted Silver Supporter
    Tampa Bay, FL
    I've got two Timmys (one from 2012, one some years old, no date inside) and they both exhibit the same problem.
    With the pedals engaged, all is fine. But when bypassed, one is completely dead while the other has only the occasional faint crackling of signal. Opening the case reveals no obvious break in the wiring or scorch marks.
    Certainly, part of the glory of a Timmy is that you can leave it on the whole time and just ride your guitar's volume knob which I did last gig...but I'd like to be able to turn it off for clean-clean tone as I set my Timmys for some mild breakup at 11am on the Gain knob.
    Anybody else experience this...?
  2. luckett
    luckett Banned
    The footswitches probably need a cleaning. It's a common problem with those types of switches.
    Iago likes this.
  3. Iago
    Iago Friend of Leo's
    Brazil
    Footswitch +1. They all fail, eventually.
  4. Anode100
    Anode100 Friend of Leo's
    Behind my beard.
    A quick squirt of switch cleaner (*not* WD40) into the footswitch (between the moving 'button' and the collar), then press the switch on and off a few times should do it.
    ...worth doing this with the pedal out of the signal chain.
    If this doesn't work, it's most likely time for a new switch.
