Timer audio bleed from LED
Discussion in 'Burnt Fingers DIY Effects' started by jddub440, Apr 18, 2020.
  1. jddub440
    jddub440 Tele-Holic
    Tacoma
    Hello fellow forum members,
    I'm having an issue with some color changing LEDs I've been trying to put as a status indicator in some builds.
    I bought 10 slow color changing and 10 fast coloring changing LEDs....they have a built in timer in the LED that I believe is unadjustable.
    My overall issue is that I can hear timer speed when I activate the effect that I installed the LED into and it is as loud as the guitar, it does a sort of glissando, squeeker fart sound between color changes and sounds kinda cool but bottomline a problem for me.
    Does anybody know of a circuit or some other way I can isolate that LED color change sound from my guitars audio signal??
  2. sirbergersworth
    sirbergersworth Tele-Holic
    St. Louis, MO
    I would think you would need a transformer to isolate it but I’m usually wrong. lol
    I tried one of those flickering leds before and he same issue.
  3. tubejockey
    tubejockey Tele-Holic
    the bozone
    Start with moving all related leads and components away from audio, especially the inputs. If that doesn't suffice, power the LEDs from a source with good bypass caps. You may even need to use a smaller disc cap in addition to the large electrolytics to keep the ESR down at your specific frequency.
