Time to rewire the MIJ Tele
Discussion in 'Telecaster Discussion Forum' started by RelicStrat, Mar 11, 2004.
  1. RelicStrat
    RelicStrat Tele-Meister
    Laguna Hills, SoCal
    I'm going to change out the cheap pots and switch and thought I might as well replace the wiring. Anybody tried this stuff? 22 gauge braided wire You'll have to scroll down to the 5'th product description. Is this any better than any other type of wire, or will regular old wire suffice?
    thanks,
    Randy
  2. 0le FUZZY
    0le FUZZY Former Member
    Kolly-forn-knee-ya
    Only iffin yew want tew
    <li>Cents the wiring is used in a low voltage/ low amperage application it won't make no nevermind about the type yew use.
    <li>22 is a good guage but any small stranded (solder-able) wire will werk. I suggest knott using solid wire cause it kin break.
    <font size=2>
    Still here </font size>
  3. Mark Davis
    Mark Davis Telefied Ad Free Member
    Bakersfield Ca.
    Fuzzy is correcto. 20-22 gauge wire works fine Radio Shack has it.
    Your also gonna need a new control panel plate cause the Japanese pots have smaller shafts than the CTS ones.
  4. 0le FUZZY
    Kolly-forn-knee-ya
    Control plate
    <li>Alst he hass ta dew iss drill them holes out fer the standard pots.
    <li>They are about a 1/4" closer on sum but still plenty of room betwixt them.
    <li>On the udder hand I haff found sum normal pots tew wide fer the cavity and hadda file the insulating materiall and/or some metal offin the edges of the pots in order tew slide them in.
    <li>The switch screw mounting cornfigger-ration may haff ta be fooled roun with a liddo also.
    Good luck!!
    <font size=2>
  5. RelicStrat
    Laguna Hills, SoCal
    Thanks for the info guys, although it sounds like my one hour long planned project just turned into a day job.
    thanks,
    Randy
  6. Mark Davis
    Bakersfield Ca.
