Timbermate issues
Discussion in 'Finely Finished' started by Jim Sams, Apr 20, 2021.
  1. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    Guys,
    I ma trying to use timbermate wood filler per Flakey's method described here year ago. Basically you liberally wipe on the Timbermate, let it dry over night and then wipe off the excess the next day with a damp cloth.
    My problem is that the filler wipes out of the pores when I wipe it with a damp cloth. Is there a trick to this method or do I need to scrape and sand instead of wiping with a damp cloth?
  2. bullfrogblues
    bullfrogblues Friend of Leo's
    Southeast Florida
    My experience is I usually rub it in with a cloth, wait about 20 minutes and remove the excess by scraping across the grain with something like a credit card. After 24 hours I then sand it flat taking care to not remove too much.
  3. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    This might be what I need to do. What grit sandpaper do you use? 220?
  4. Sea Devil
    Sea Devil Friend of Leo's
    Brooklyn, NY
    I would use 320 or 400, maybe even 500. You're not sanding the wood.
  5. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    OK. thanks for the tips.
  6. Flakey
    Flakey Friend of Leo's
    The Land of 10,000 Lakes
    You're wiping off ACROSS the grain, right?
    bender66 likes this.
  7. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    Yes. What type of cloth do you use? I an using and old dishtowel and it is taking the filler right back out. Is it possible I have it too damp?
  8. stepvan
    stepvan Tele-Afflicted Silver Supporter
    out there somewhere
    I would try a different type of cloth, terrycloth may be part of the problem. Smooth cotton rag might be better
  9. bullfrogblues
    Southeast Florida
    I don't sand finer than 220, any more than that and it can be polishing more than sanding and cause adhesion problems. IMO
  10. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    reapplied last night and scrapped off excess with hotel card key.
    I'll try again wiping tonight with a T shirt material on half the sample. If that doesn't work, I'll try sanding.
    bullfrogblues likes this.
  11. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    Tee shirt material works much better.
  12. Flakey
    Smooth cloth and not too damp. I use paper towels now and make sure you wring out the cloth after every rinse.
  13. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    Flakey method might work after all. I think I had the mix too wet and the towels too rough. I think I might need one more coat
