Tickled Pink: Jupiter's Es-335 Build
Discussion in 'Tele Home Depot' started by Jupiter, Mar 17, 2016.
  1. Barncaster
    Northern California
    Looking good Jup but for shop safety sake, please consider shaving your fore arms. You are a fire hazard!
    JazzHands and johnnyha like this.
  2. R. Stratenstein
    Loganville, Ga.
    That's an excellent plan, Jupe. Probably even better if I understood one word of it, but no doubt, excellent. :mad: These Gibsons are troublesome guitars, aren't they?
  3. Jupiter
    Osaka, Japan
    It is surprisingly difficult to explain these things clearly to Fenderish folk. :D
    But yeah, there sure are a lotta steps to just getting a guitar body! Even a sludge like me can get a tele body cut out of a plank and routed in a day. Well, a weekend, maybe. I mean, I've never actually DONE it, but... :oops:
    But not so troublesome, really, so far, in the sense that each procedure has been fairly simple; there are just a lot of procedures, and most of them involve cutting up wood that's not even going to wind up as part of the guitar, which can feel a little weird sometimes. I'm collecting a mighty big stack of oddly chopped up plywood around my bench. Don't really know what I'm going to do with it all after this is done. Am I really going to ever make another one? :confused: The next thing I'm interested in is a small-body acoustic archtop. Or some kinda bari. And this lap steel for my FIL. Jeez, I'll be over 60 before I get through alla that stuff...
    Anyway, you'll see my rubber soon enough. :cool:
  4. Barncaster
    Northern California
    ? Think of the children man!!!
    crazydave911 likes this.
  5. Jupiter
    Osaka, Japan
    It literally had to be said. :p
  6. Jupiter
    Osaka, Japan
    'Kay, so this is what I'm talking about. First, 10mm thick neoprene, to conform to the arch when I press down.
    You can see that leaves the plate sitting proud a fair bit--not too much, I hope...
    My goal is for the sides of the plate to sit flush on the form once I crank everything down, just to help make sure that the plate stays flat, instead of getting some funky warp glued into it.
    Then the spruce will go down, and it gets the Hard Rubber Treatment:
    Again, 10mm, but much more rigid than the neoprene underneath. This should allow the kerfing to flex a bit to conform to the side-to-side curvature of the arch.
    Then a plywood caul on top of that, and... Some kind of clamping system, I dunno :rolleyes:. None of my clamps are deep enough to reach to the middle. I have a square of plywood that might work on top of the whole shebang.
    Any reason why that might not work?
    I probably don't need to worry that much about all this; the plates are NOT as deep as my PDF, which means this spruce is gonna get planed pretty thin by the time it's flush, so it prolly won't have much effect on the shape of the plates no matter what I do...but just in case, I'm worrying about it.;)
  7. telemcCaster
    telemcCaster Tele-Holic
    Michigan
    Make a plaster cast. Use it as a backer. Saran wrap over plate then your plywood cutout then pour in plaster. Level.
    jpbturbo likes this.
  8. Jupiter
    Osaka, Japan
    Does that mean you don't have faith in the neoprene underneath? 'Cuz the plaster cast does seem good, especially if I were going to make a bunch of these, but as a one-off (or maybe two off?), it sounds like a whole-weekend side trip. Gotta find plaster somewhere in Japan (not impossible, but I haven't seen it before in my usual haunts), and I've never worked with it before.
    I dry-fit my Plan A and it seemed to work well:
    It is admittedly ugly, but I was able to get the plate down flush with the top of the form, with no cracking sounds, and it all looks copacetic... Am I missing something?
  9. telemcCaster
    Michigan
    I didn't realize you had gotten that far. Looks like it'll work fine.
    Plaster is readily available in the hardware stores here so that's why I suggested it.
    Jupiter likes this.
  10. nosmo
    nosmo Friend of Leo's
    Lake Jackson, TX
    I thought he had one of your minions Rob.
  11. Barncaster
    Northern California
    Hmmmmmm, you're right. Maybe that was Mr. Yeknom's cousin Mr. Pmihc.
  12. R. Stratenstein
    Loganville, Ga.
    You should get the plaster, Jupe. It'll come in handy when you get groupies, too.
    "Then the spruce will go down, and it gets the Hard Rubber Treatment:"
    Oh, you big savage, you!
    (I don't need somebody to point out all the softballs pitched out there, but I'd feel better responding if Brainy's steady hand was still on the till at times like this. Dammit)
    MM73, ajr969 and BluesBlooded like this.
  13. Jupiter
    Osaka, Japan
    They're all for him; if they bring ol beeb to mind, they've done their job, whether anybody takes the bait or not.
  14. Jupiter
    Osaka, Japan
    So I glued er up before yesterday, started squeezing the juice out, and left everything for 12 hours. Every once in a while for the first couple hours, I went and snugged up the clamps a little, in case the foam pad was compressing.
    This morning, I popped it out and took a look.
    No apparent damage: that's a win, right? lol The spruce drifted a little bit under the clamps (about 1mm up and to the left); might need to think about that for the second one.
    Seems reasonably flat still...
    You can see that the foam underneath actually did compress about 50%. Not thrilled about that, but we'll let it sit a day and see if it springs back at all. I have another thin square of the same stuff that I can throw under there for the second one, or I might take a swing at Ken's plaster form.
    After sitting there for a couple minutes, it seems that the plate is not perfectly flat. I might have clamped it too hard, but it's manageable; I can press it down easily with my fingers. I'll certainly clamp the edges down when I plane the spruce, and removing that material will probably let it lie flatter. Should be no problem when I glue the plate to the garland.
    So now I'm questionizing myself: plane this flat (which sounds more fun), or do the other plate up (since I got all the jigs and stuff lying around already)...
  15. R. Stratenstein
    Loganville, Ga.
    Looks good from here. It would make more sense to do the other side, since you got everything out. So I'd say, plane the one you just did. You need a break from practical every so often.
  16. Jupiter
    Osaka, Japan
    Okay, I'll--wait, what? o_O
  17. BluesBlooded
    BluesBlooded Friend of Leo's
    Sherbrooke, Qc, Canada
    You managed that quite well! It's looking darn good!
  18. Tonetele
    South Australia
    You're doing everything right Jupe! Can't wait to see/hear the finished product.:)
  19. oldrebel
    oldrebel Friend of Leo's
    Lynchburg Tennessee
    Looks like it is coming together nicely. Great job!!
  20. Jupiter
    Osaka, Japan
    Thankee kindly!
