Since I am hiding the adjustment screws for the pick ups I'm not using the mounting rings/springs. I am going to use foam underneath like Jazz bass pick ups.
I'm not confident in the machine screw holding in the wood, and I looked all over town and couldn't find threaded inserts small enough.
So I got some nuts and screwed them on some threaded rod, chucked it in the drill press and ran a file against it until they were rounded off.
Like so:
image removed
image removed
Drilled the hole for the threaded portion first just deep enough to flush mount to the bottom of the route.
image removed
Then drilled the hole for the screw to go through to deeper, and glued the inserts in place.
Last little bit of fiddling figuring out the bridge mounting.
image removed
I considered using the magnets to hold the bridge plate in place too, but figured I better use some screws.
image removed
If I am using screws I wanted to hide them.
I drilled the mounting holes so they will be hidden by the saddle adjustment screw/spring when the bridge is assembled
Picked a new set of micro-mesh pads up today, so tomorrow is adventures in wet sanding.
It shouldn't be too bad, gonna start with 800 grit to knock the high spots down then switch to the micro-mesh.
