Three way with center blend
old school fender
Georgia
As the thread title implies I'm in need of a wiring diagram for a three way switch that maintains position one and position three stock (position one, bridge maintaining tone control, position three,neck maintaining tone control, but using position two purely as a blend control), roll the tone knob one way, more bridge, the other" way , more neck.
From what I've found so far what I'm looking for is not traditional "blackguard" wiring since it defeats the tone control in one or more positions (one or three, or maybe both, can't remember). I want to retain tone control in both one and three positions and use tone control for "blend" in position two only.
If you have this diagram and could post it or supply a link where I might find it it would be greatly appreciated but please don't bog me down with "here's one you might like even better'. I've spent enough time down this "rabbit hole" already. Thanks!
Wallaby
Here
Just making sure of something -
You're looking for the blend to be for tone control adjustments when using the center switch position?
Or would the blend be for blending volume control but using the tone control knob?
old school fender
Georgia
The way I worded it could have been confusing. What I'm trying to accomplish is using the tone control, when in position two only (bridge and neck pickups) as what I would term a balance control. I guess that would be considered a volume control between the two pu's as well. Hope I didn't confuse you more. Terminology can be a tricky thing!
SPUDCASTER
Grangeville, Idaho
So, you want tone control only on the B/N position?
Then, you want to control the volumes of the pickups individually in the middle position?
A friend of mine has a master tone, master volume and a blender pot to achieve all three positions. No switch.
Then you could use a no-load tone pot so you could always utilize the tone pot if needed.
Not sure if that's what you're after?
old school fender
Georgia
Yes. Using the tone control.
old school fender
Georgia
mountainhick
Rocky Mountains
You said you don't want to hear it... sorry.
Not that it can't be done, but I do not see a practical way to retask the tone pot as you want for both functions tone and blend. You might be able to get there with a super switch that would switch out the tone cap in middle position, but then you're dealing with a 5 position switch. And the tone pot itself is not a good choice for blend in the first place.
The best blend IMO is to use a double decker MN type which would entirely replace the tone pot. This type pans between clockwise and counter clockwise rotation so they are both on full at the center, one or the other at end ranges. It can in effect replace the switch entirely, or can be left at any chosen blend in middle switch position and blend tweaked on the fly between the two pickups.
(EDIT: just adding that using a standard tone pot as a blender (Tone pot with the cap disabled/lifted in blend mode) gives you only the option of one of the pickups on full, and blending the other with it, not panning between them. This is the kind of arrangement used on strats. In bridge position it is all bridge, and neck blent. In neck position it is all neck and blent bridge.
If you want to keep both volume and tone function, you need 3 pots (if you use an MN it is actually 4 pots (2 double deckers)) I would use a dual pot with stacked knobs for vol tone, and retask the tone position for blend.
Block diagram. (tone control not shown but wired off Vol as usual.) If you really want to go this route I can draw a detailed wiring diagram
old school fender
Georgia
Yes. Having one pickup on full and blending the other with it would suit my purpose. Wouldn't necessarily have to involve panning. "Bingo" !
mountainhick
Rocky Mountains
Solaris moon
Fort Waste
You could use a PUSH - PULL pot to make the necessary modifications without compromise. You could wire it so that the pull could activate the tone while the down position makes it a blend control. But this would be tricky to do but it could be pulled off. I don't know of any other way that would allow you to have the switch with the two blended without this feature.
old school fender
Georgia
I've about come to the conclusion you're right. The only way to accomplish this would be with a stacked pot.I was originally thinking along the lines of a stereo receiver balance control but I seem to recall that they are also a stacked , or dual control with no tone circuitry involved. Oh well, back to the drawing board!
