Threaded saddles for a bender ok?
Discussion in 'B-Bender Forum' started by 8painting, Mar 1, 2010.
  1. 8painting
    8painting TDPRI Member
    Indiana
    I've got the regular steel saddles on my b string at the moment.
    While everything is coming in and out of tune just fine when bending, sometimes when i pluck with my finger or thumb, it'll move the string side to side a little bit.
    I figured putting a threaded saddle on will fix the side to side movment, is this ok, or would there be any binding issues?
    Thanks!
  2. coolbreeze475
    coolbreeze475 Tele-Meister
    Grand Rapids Mi.
    I had to put notches in my saddles when I installed the Hipshot because the strings were sliding side to side when I plucked. It was an annoyance. It helped out alot.
  3. ironweed
    ironweed Tele-Meister
    mid-missouri
    I used threaded saddles for my b-bender for a while, and they worked fine. No string breakage issues, and no side-to-side string wallow. But I got lonesome for the darker sound of brass saddles, so I changed back.
    The b-string needs a little help to get "seated" in the brass saddle. When I changed back to brass, I lined up the b-string right where I wanted it and gently "whacked" the string to push it into the softer brass to start a tiny groove. The b-bender groove will continue to wear, but it will take a long time (years?) to wear into the brass to the point where a new saddle is needed.
  4. Silverface
    Lawndale CA
    I've had some vintage threaded ones on my Nashville West for several years now. use either threaded or some type of compensated brass.
