THR 10C Issue
Discussion in 'Amp Central Station' started by howlin, Apr 30, 2019.
  1. howlin
    howlin Tele-Afflicted
    Who wants to know?
    I just bought a used Yamaha THR 10C. Overall it's great. My only concern is when it's set on the US Blues setting there is a significant drop in volume. I can reset the dials and get it to a usable volume but I'm pretty sure that this shouldn't be happening. Anyone else have this problem? If so, did you find a solution?
    Thanks.
  2. rze99
    rze99 Poster Extraordinaire
    South London UK
    I have the same amp and yes the levels are different. You can change them via the editing software. I think, but since I only use it for quiet noodling, I can't be bothered with all that myself.
    Danjabellza likes this.
  3. howlin
    Who wants to know?
    Yeah, I know what you mean. I was only thinking about if/when I decide to sell it. I'm not into selling something that's broken - at least not knowingly.
  4. beninma
    beninma Friend of Leo's Silver Supporter
    Massachusetts
    Yah it's an annoying issue but not that big of a deal since you're probably never going to be using it in a performance situation where you need to switch them on the fly and keep the volume the same.
    I have a THR5, on mine the volume levels generally start low on "Clean" (Fender) and gradually go up as you go up to the more gainy models.. it's a huge difference in volume between the Clean (Fender) and Modern (Mesa) models if you just switch and don't go reset all the knobs.
    It is pretty annoying if you're in a room practicing/jamming/taking a lesson with someone else. Just leads to extra unnecessary button pushing & dial adjusting.
  5. Honest Charley
    Honest Charley Tele-Holic
    Sweden
    I think this volume thing (among others) is about the whole idea of the THR10 concept. It is the same for the tone circuit in the different "models". They work in a different way for each amp and that is very much intended.
    The THR10 can be seen as nothing but a fairly big computer which simulates not the sound of a certain amp but the electronic circuitry for that amp.
    At least I think so. :)
    TokyoPortrait likes this.
  6. No457 Snowy
    No457 Snowy Tele-Meister
    The THR series is great but they are quite a few years old now (7 years or so?), especially for an item that embraces newer "technology" and I think Yamaha need to update this series, adding things like Bluetooth and taking into account user experience/feedback, etc.
  7. rze99
    South London UK
    I have to say I love the Matchless emulation on the C model with my Teles for low level fun.
    aux8 likes this.
  8. DavidP
    DavidP Friend of Leo's
    Vancouver, BC
    ... like rze99 said, different amp models have different gain levels; for sure install the THR Editor to tweak and save in presets.
  9. Danjabellza
    Danjabellza Friend of Leo's
    Pahrump, nv
    Yeah. Very different volumes across each amp model. The volumes/gain stages and EQ stacks are drastically different depending on which model you use.
  10. Finck
    Finck Tele-Afflicted
    São Paulo - Brazil
    I have a THR5, it has not the same channels as yours, but has the same issue, the volume drop between clean and higher gain is brutal.
    I think you can solve the problem on your model tweaking the presets with the Yamaha Editor (mine has not that functionality).
  11. doolbon
    doolbon TDPRI Member
    california
    This. I have the 10c and this is normal
  12. kelnet
    kelnet Telefied Ad Free Member
    Port Moody, BC
    It is neither an issue or a problem. Yamaha meant to do that. Some amps are quieter than others. Yamaha has reflected that in the THR10. If the volume levels were all the same, they wouldn't be an accurate representation of those amp styles. Of course the high gain setting is louder. That's what makes it high gain.
    I tend to always use the same setting with mine. It's a practice amp for me, not an alternative to having those actual amps.
  13. Finck
    São Paulo - Brazil
    I see. But it's annoying the same way...
  14. TokyoPortrait
    TokyoPortrait Tele-Holic
    Tokyo, Japan
    Very much yes.
    Also a looper, at the end of the chain, so you can record rhythm say, as one kind of amp / settings / effects, play that back and play over it / record more layers with others. Some simple built in drum backing tracks with tap tempo would be cool too.
    Pax/
    Dean
  15. aux8
    aux8 Tele-Meister
    Ireland
    Me too. I overwrote the #1 preset to be the Matchless/Vox/Class A model with some compression.
    The US Blues setting is generally my least favorite.
