This Little Amp Is Trying to Kill Me and My Girlfriend
Discussion in 'Shock Brother's DIY Amps' started by ArcticWhite, May 22, 2020.
  1. ArcticWhite
    ArcticWhite Tele-Afflicted
    Portland Oregon
    I built this little 7 watt guitar amp out of a Silvertone organ amp.
    Last night, I plugged it into an ungrounded, three prong outlet in my garage. My girl came in and I put my arm around her while my left hand was holding the strings. I felt the small of her back buzz, and I immediately let go.
    Unplugged and started testing things.
    The outlet is wired correctly with the exception of the lack of a ground. Checked polarity with a plug in tester.
    I measured the voltage from the strings to known ground at about 55V AC.
    Opened the amp up and did a visual inspection. Can't see anything wrong.
    The amp works fine. But there's a problem somewhere.
    For comparison, I plugged my Princeton Reverb into the same outlet with the same guitar&cord combo, and there is no measurable voltage on the strings.
    RichCuellarPDX and Dan R like this.
  2. Lowerleftcoast
    california
    EDIT:
    Try lifting the PT off the chassis. Maybe a short from the winding.
    Look for frayed insulation on AC wires.
    Archtop Bill and ArcticWhite like this.
  3. ArcticWhite
    Portland Oregon
    (Edit: Because my response doesn't make sense in context anymore.)
    Center tap is here, soldered to one of the cap can tabs.
  4. printer2
    Your PT secondary, I take it the center tap is returned to the chassis?
  5. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Green-eyed jealousy?
  6. ArcticWhite
    Portland Oregon
    Do you mean an internal short, or one of the leads?
  7. jimbo735
    jimbo735 Tele-Afflicted
    Michigan
    Is it a optical allusion or does it look like on the input jack the guitar cord tip would touch that resistor when plugged in.
    Is the amp in a cabinet your on a cement floor Im assuming,thats always trouble from what I have experienced in the past.
    53Strat likes this.
  8. Badside
    Badside Tele-Holic
    Montreal, Qc, Canada
    That big green wire, that's the mains ground right? Doesn't look it's connected to the chassis no? Should be.
    King Fan likes this.
  9. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    Ordinarily that'd be a huge clue, but the OP's outlet isn't grounded! So it would not make a difference in this specific instance.
    (It's grounded through the attachment of the last terminal on the strip to the chassis but you can't see it in the picture.)
    SecretSquirrel likes this.
  10. tubegeek
    Brooklyn, NY
    What's the insulated RCA jack for? Line out?
  11. Lowerleftcoast
    california
    An internal short to the plates of the PT which are bolted to the chassis could do it.
    One of the leads carrying AC could be frayed and make contact either in the PT or as they pass through the chassis.
    ArcticWhite likes this.
  12. ArcticWhite
    Portland Oregon
    Tremelo footswitch jack
  13. ArcticWhite
    Portland Oregon
  14. ArcticWhite
    Portland Oregon
    I did try testing the transformer leads for shorts and didn't find anything.
    I try isolating it.
    Lowerleftcoast likes this.
  15. RodeoTex
    RodeoTex Doctor of Teleocity
    Nueces Strip
    Is one side of the PF xfmr grounded, or at least to the neutral?
    I'm suspecting 0v is floating.
    This is very '60s. It may work out for you.
  16. RollingBender
    RollingBender Tele-Afflicted
    SW Minnesota
    Rubber grommets in every chassis hole which wired pass through.
    reverb11, 999patton, King Fan and 4 others like this.
  17. ArcticWhite
    Portland Oregon
    It's soldered to a grounded tab on the cap can.
  18. GoldDeluxe5E3
    GoldDeluxe5E3 Tele-Afflicted
    Concord, California
    Sorry, I keep reading your original post, and you say "ungrounded, 3-prong outlet".
    If you plug a 3 prong amp plug into an ungrounded socket, set the amp on your garage floor, your girlfriend comes in to visit and she's barefooted, you're holding your strings of your guitar plugged into the ungrounded amp, and you touch her back, I wouldn't be surprised if you feel a shock. You shouldn't be rummaging through your amp circuit to find an electrical problem.
    It can only be one thing. Your girlfriend seems to have an electrical malfunction.
    bloomz, nvilletele, Danb541 and 9 others like this.
  19. mfguitar
    mfguitar Tele-Afflicted Silver Supporter
    Buffalo
    You really need to have that garage wiring checked out :)
  20. ArcticWhite
    Portland Oregon
    I did not say "ungrounded 3-prong plug". You did.
    Intentionally misquoting people is rude.
    Delete your post.
