Old Verle Miller
It would help if you can post a picture of the body including the bridge.
Something else you might try to keep a neck from shifting laterally is to increase the friction between the neck and the body by gluing a piece of 320-grit sandpaper to the surface of the pocket face up. (Depending on the glue you use you may have to let it sit for a day.) Then when you clamp and start drilling and putting in the screws, the neck probably won't shift as much.
