The other day I was browsing through the new threads and came across someone's post about buying a ES335. Well, didn't that get me thinking! quick check on some local stores and stock is relatively low, and the prices of course, have gone up over the last two years. There are a couple of the same incarnation available, one that is described as "ES-335 Figured Semi- Hollow Iced Tea". It lists for $5099CDN.
The parts description is different than on the 64' Reissues, which use Custombucker Alnico III PUs, compared to the T type found on the other. Reviews on the T type are not that great with most people seeming to swap them for the BB Alnico III, a modest cost. Not sure why there's a $2500 difference in price between the Reissue and the one with the figured top?? Personally, I like the look of the figured top more than the plain grain tops found on the "Reissues". The "figured top" version appears to be a generic 60's model, with their new T type PUs. Aside from the obvious difference in PUs, am I missing something else on the difference between these two? Those Custom BB Alnico III's can be had for $280US.
And then there's this one for $4450CDN, referred to as a "ES335 DOT Semi-Hollow Body" The primary difference between it and the "figured top version is the figured top, and for that it's $500 less. Still, the top on it is quite nice.
www.long-mcquade.com
Figured Top: https://www.long-mcquade.com/174100...-Guitars/Gibson/ES-335-Figured---Iced-Tea.htm
Reissue: https://www.long-mcquade.com/166248...n/1961-ES-335-Reissue-VOS---Vintage-Burst.htm
Cheers!
Gibson - ES-335 DOT Semi-Hollow Body Electric - Vintage Burst
Cheers!
